Setting up Elanscan on Windows Vista
Postby jon3929 » Fri 05.09.2008, 21:59
Hi,
Whilst Ive seen a few threads regarding Vista, none seem to answer the issue i have.
I had Elanscan set up on my old desk top PC running XP, but have just got a laptop with Vista, and I cant get the drivers set up. There appear to be a couple of differences which I cannot figure out.
1. When plugging in Elanscan it does not appear on the device driver as a comms port, but "other" device
2. When trying to update the driver to Elanscan, vista appears not to let you select a file, but only to search a folder
3. Without a driver I obviously cant configure it to a comms port....
3. Is the FTDI driver i used on XP the right one for Vista?
Whilst Im clearly no IT wizard, im not that IT illiterate!!! or at least i thought not....
Hope someone can help!
cheers, Jon.
jon3929
Re: Setting up Elanscan on Windows Vista
Postby GeoffSmith » Fri 05.09.2008, 22:12
Jon,
No experience of Vista at all, but FTDI claim them to be compiant. Check out their drivers page.
Geoff
Postby John_W » Fri 05.09.2008, 23:42
jon,
Sympathies.
I bought a new laptop PC with compulsory Vista at the beginning of the year. I've not managed to get Geoff's USB interface to work with it. I'm using my old laptop with serial version interface for Elanscan.
I don't like Vista. It thinks it's in charge of the computer. I'm having trouble telling it that actually I'm the person who paid all the cash and therefore I'm the person in charge of it.
If you find a solution, do tell....
Postby ESM » Sat 06.09.2008, 11:50
Have you tried the executable setup file here?
I haven't got Vista (avoiding it like the plaque in fact) but it might be worth a try.
ESM
Postby jon3929 » Wed 10.09.2008, 19:58
Well I have done it......
As suspected it was a process issue rather than an incompatibility or something more serious.
I used the same VCP drivers as for XP and the file that ultimately enabled the device was called "ftdibus". Before starting I unzipped all the files onto my desktop asI had no success in getting Vista to searh folders, the files needed to be fully exposed and I just used my desktop for ease.
Here's how i think I did it:
1. When the elanscan interface is first plugged it, it appears as "elanscan interface" but as an "other device" not a port .
2. Right clicking and selecting the driver tab reveals it has no drivers allocated.
3. Following the process to assign a driver, select the manual method under "browse my computer"
4. Then select "let me pick from a list" option
5. Then select the "have disk option"
6. Then select the browse for file option.
7. At this point it is looking for a *.inf file which is not correct
8. Delete the file extension
9. Then select Desktop and it automatically selected the driver file "ftdibus"
10. Select ok and it says the driver has been successfully configured.
HOWEVER - it hasn't.
11. When looking again at the device in the device manager, it now shows Elanscan as a COM PORT, but also showing a yellow exclamation mark indicating a fault, and without a com port number.
12. Repeat exactly, the process from 2-10 above and reassign the driver for a second time.
13. Again it will say the driver has been successfully configured.
14. Checking in the device manager, it now shows the device as a COM PORT and mine defaulted to "COM PORT 13".
I then could set the latency timer to 1 (because it now recognised the device as a comms port), and then set Elanscan to communicate through port 13.
Lo and behold it communicated perfectly and works a treat.
Its nice to actually be able to put up something useful rather than just ask questions. Hope this is useful to others.....
cheers, Jon.
jon3929
Postby jon3929 » Wed 10.09.2008, 20:01
Ive no idea what that animation is all about............. :-|
jon3929
Postby John_W » Wed 10.09.2008, 20:50
Jon,
Well done. :smt038
How on earth did you work that one out?
I'll try it on my laptop when I can get it back from the kids.
jon3929 wrote:Ive no idea what that animation is all about............. :-|
Yeah ... that's what they all say.
Postby tigerdog » Thu 11.09.2008, 05:44
I knew there was a reason I kept my ancient Toshiba running Windows2000 for ElanScan. :)
Great work, Jon. Well done!
Postby GeoffSmith » Thu 11.09.2008, 13:22
And that's progress? :|
Postby CJ101KT » Thu 11.09.2008, 15:47
I will be getting round this issue one way or another on my Acer laptop that is running Vista Business. I will let you know how I get on. Stay tuned!
CJ101KT
Postby stevieg8571 » Mon 02.05.2011, 23:12
Hi,
I'm having trouble getting my Vista equipped laptop to work with elanscan.
Is there a specific 'ftdibus' driver to use? I've downloaded a generic one but it still doesn't work.
Any help greatly appreciated.
Steve
stevieg8571
Postby whippit » Mon 02.05.2011, 23:40
hi steve
i had mine running last year on vista, then the laptop died and bought a new one with windows 7, both loaded the same
i'm useless on computers, so this is not that technical,
i just downloaded the drivers on elan scan page ,
then all i had to do is look for which com port to use , top left, set up - set com port , i just changed them until i had a signal,
the only prob i have is i think the latancy timers are to high,
but i'm not that technical to slow them down,
i'm sure someone will point you in a clearer direction soon
whippit
Postby stevieg8571 » Mon 02.05.2011, 23:47
Cheers/
I'll have another go tomorrow, give it a good swearing at.
That should fix it!!
stevieg8571
Postby GeoffSmith » Sun 14.08.2011, 16:57
John Wham was having trouble with Vista - although the interface drivers were reporting it as a COM port ES reported that "com port inactive". The problem was that an old version of ES (2003 vintage which, amongst other things, you could only select com ports 1 to 4) was being run and once it was replaced with Ver 0.10.12.71 there was no problem.
Postby John_W » Wed 17.08.2011, 22:29
Thanks to Geoff (and Bob) for setting up my Vista PC for ElanScan (and to Specky for access to his car to test it). Hopefully I'll now be able to get some more scans which I've been unable to do since my old serial-port PC went belly up several years ago.
Postby Stryker » Wed 06.06.2012, 19:29
Hi I am trying to set up Elan scan on vista but it don't like it I have a message "Access violation at address0041B89B in module Elanscan_Beta,exe Read of address 0000008'" anyone else got this and can you guide a PC learner how to get these 2 speaking to each other.
Help will be much appreciated
Stryker
Postby epipete » Wed 06.06.2012, 23:07
John_W wrote:jon,
Sympathies.
I agree with John re Vista and having recently got Windows 7 I can't say that that is an impovement on Vista in terms of intuition or handling!
I think I'll be running elanscan off my old XP laptop!
Postby Stryker » Thu 07.06.2012, 18:11
Reckon I'll be doing same got old laptop wound up saved elanscan to it will try at weekend it runs XP thanks for help so far
Stryker
Postby rip » Sun 16.09.2012, 18:04
I've just tried to run ES on my laptop for the first time since re-installing Windows (v7 64-bit)
I don't know how I got it running before because it won't allow me to install one of the drivers I had.
I googled 'FTDI drivers' & found this
As mentioned earlier, I had to install it twice but the laptop now sees the cable fine.
Now to test it on an Elan...
Postby Steve A » Wed 27.03.2013, 14:13
:? So if I was looking to get an old laptop to run ES (I am) would it be advisable to get one that is running XP to avoid grief :poke:
The last thing I want to do is to get one and then wish I'd got another :roll:
Return to ElanScan
