Escutcheons - Carbon Fibre
Postby F1 LOTUS » Thu 10.07.2008, 06:57
Double-sided sticky pads will also do the trick without drilling any holes.
F1 LOTUS
Postby Elanlover » Thu 10.07.2008, 13:15
F1 LOTUS wrote:Double-sided sticky pads will also do the trick without drilling any holes.
That's a possibility. Would eliinate drilling and make for a cleaner look. If I recall, there's not much to attach any tape too though. Will have to have a look later. Simple two sided tape wouldn't work - would need some of that foam stuff to ensure good contact. Good thought!
Postby Foo » Thu 10.07.2008, 14:52
Elanlover wrote:I am curious about one thing though. On the OEM escutcheon, there is a conical head screw that advances into a socket in the escutcheon. Makes it so, when you tighten the screw, the head has something to push up against so to speak (am i being clear or confusing?) But, there's nothing like a socket for the screw to rest in on these escutcheons (especially if we are drilling a plain hole). So, what are people using to fasten it down with? The OEM screws or something else????
http://en.wikipedia.org/wiki/Countersink
Foo
Postby Elanlover » Thu 10.07.2008, 15:51
Foo, I DO know what a countersink is :roll: Its that thing in the kitchen.....right? On the counter? Holds water and usually dirty dishes? :wink:
MOTO!
I did consider using a countersink bit but the problem I think is that the CF is so thin there's not enough material to create a decent sized countersink for the screw to sit anything close to flush. The CF escutcheons (getting tired typing that out :roll: ) are easily 1/4 as thin as the originals. A "standard" screw (button head or hex) will sit too proud on the surface and scrape your knuckles when you open the door. I do like Brians's idea and will see if we can get that to work.
Postby Jackonicko » Thu 10.07.2008, 15:57
You lucky lucky folk - any superseded plastic escutcheons gratefully received......
Jackonicko
Postby Nige » Thu 10.07.2008, 20:29
Jacko, if there is to be another run I'll let you know.
As far as knowing where to drill I suggest a piece of masking tap on the back of the escutcheon and a pen or pencil stub in the screw hole inside the door. Offer the escutcheon up and the pen or pencil will leave a witness mark on the tape and that's where you drill. I recommend a small pilot hole from the rear, masking tape over the hole on the front face, drill the actual size hole and then countersink to taste :wink: .
Back in Blighty
Nige
Postby redvette6327 » Wed 16.07.2008, 16:32
Just returned from a great vacation in Europe and found a package waiting for me. The parts are very well made. I think I'll try the double sided tape idea before I drill.
redvette6327
Postby Elanlover » Wed 16.07.2008, 17:20
I've drilled and was just able to get the screw to sit reasonably flush with the face of the escutcheon. I couldn't find enough flat surface under the escutcheon to get the tape to stick confidently.
Postby vix.tabellae » Sat 02.08.2008, 21:32
I would like a set if/when they become available. Thanks.
vix.tabellae
Postby garymb » Thu 21.08.2008, 20:56
vix.tabellae wrote:I would like a set if/when they become available. Thanks.
ditto :)
garymb
Postby RayD » Thu 21.08.2008, 21:36
I've not read this thread so it may have already been mentioned...
One reason for the original ones breaking is there’s a gap between the back of the escutcheon and the fixing on the door, a bit of over tightening would guarantee to whip the front off.
It might be better to fit a spacer at the back of any new, or yet to be broken ones.
Ray
RayD
Re: Escutcheons - Carbon Fibre
Postby Steve A » Thu 18.09.2008, 22:42
:poke: After seeing these fitted to Elanmans car at Hethel, I want some :poke: will there be another production run of these Nige?
Postby garymb » Fri 19.09.2008, 16:44
Steve A wrote::poke: After seeing these fitted to Elanmans car at Hethel, I want some :poke: will there be another production run of these Nige?
I think that makes 3 customers so far-- how many do you need for another run?
garymb
Postby markiep » Sat 20.09.2008, 23:50
i'd like some so thats four.
it doesn't matter what temperature a room is it's always room temperature.steven wright (not to be confused with steve wright)
markiep
Postby Jackonicko » Sun 21.09.2008, 00:34
1) Tweet
2) Foo
3) Steve A
4) MarkieP
5) Jacko
Jackonicko
Postby theelanman » Sun 21.09.2008, 00:41
turnin out to be rather popular :-D :-D :-D :-D :-D :-D :-D
Postby tweetdriver63 » Sun 21.09.2008, 01:04
Jackonicko wrote:1) Tweet
2) Foo
3) Steve A
4) MarkieP
5) Jacko
1) Foo
2) Steve A
3) MarkieP
4) Jacko
Sorry, none for me right now. Thanks.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Postby garymb » Sun 21.09.2008, 11:59
1) Foo
2) Steve A
3) MarkieP
4) Jacko
5) Garymb
garymb
Postby vix.tabellae » Mon 22.09.2008, 17:31
1) Foo
2) Steve A
3) MarkieP
4) Jacko
5) Garymb
6) Vix.Tabellae
vix.tabellae
Postby Exbury » Mon 22.09.2008, 21:59
1) Foo
2) Steve A
3) MarkieP
4) Jacko
5) Garymb
6) Vix.Tabellae
7) Jason N
If it helps think I would be up for a pair too! Would this be worth putting in as a new 'Group Buy' and linking to this thread? Might get more interest as I am sure not all members check every post! :D
Exbury
Return to Interior
