by mnemonix » Mon 05.01.2009, 00:35
Hypothetically... if I wanted to calculate my miles per gallon from the data provided from the ecu, what would be the best approach for determining fuel use? Air/Fuel ratio and cylinder displacement ? Injector duty cycle & pulse width ? Some other route ? or is the data not accurate enough to derive a usable mpg from ?
I'm toying with ideas for plug in trip module that might display useful data, though in the first instance it could be done with an excel spreadsheet export from Elanscan.
Chris.
mnemonix
by GeoffSmith » Tue 06.01.2009, 14:15
I believe my Scirocco used injector pulse width, engine speed and road speed - it was reasonably accurate.
- Kitty Fiddler
Return to ElanScan
