by mikeydude » Wed 16.09.2009, 14:02
I need an address in the states to have a cas delivered to!?
The only place I can find is Ricart at the moment, unless anyone else knows of supplier?
If they could then send it it on to me and I will, of course, pay the courier charge.
mikeydude
by lotos » Wed 16.09.2009, 14:53
I'm always up to help a fellow LEC-er. Drop me an email to discuss.
lotos
by nsr250 » Wed 16.09.2009, 15:06
I'd be glad to do it too.
Don
'91 Elan
'87 Milano
'91 318is
'02 Protege5
'02 DRZ400s
'91 VFR750
'98 VFR800
nsr250
by mikeydude » Thu 17.09.2009, 11:41
Many thanks guys.
I have managed to get Ricart to send the CAS direct!
Many thanks to Marcus for assisting me there!
Now then...if the CAS is becoming hard to get hold of then should we be making sure people keep the old ones that they swap out?
Since it has already been demonstrated that the worn bearing and "o" rings can be replaced and that the unit itself is not rivited or welded together making recon straightforward.
And, of course it is well know that the poor reliability hall effect sensor can be replaced.
I will have a go at reconing my old one, as the bearing is right royaly screwed in mine! and it's only two quid to buy
mikeydude
by tigerdog » Fri 18.09.2009, 02:12
Good idea on the recondition, Mikeydude. If you manage to pull it off, please take a few pix and add it to the wiki. We'll all head that direction eventually and we'll benefit from your experiences.
by mikeydude » Fri 18.09.2009, 10:46
Will do...it will be a winter thing though..so might be a while
mikeydude
Return to Off Topic Area
