The first performance upgrade I did to this car was to fit a Quicksilver Exhaust (which I later discovered gave a power increase to almost 200 BHP at the flywheel, 172 at the wheels, which created a lot of confusion from the testers, as no one could believe that this single item could be responsible for such a figure). Not bad for a 2" pipe and no need to worry about boost creep.
It gave a good, noticeable, but not amazing, increase in acceleration and definitely brought the power on sooner, nice sound too, without being at all loud.
So now I wanted 220 BHP at the flywheel, because this car is so capable, but I have been warned about torque steer by Lotus 'experts', about melting pistons, turbo lag and failure of components..........
After extensive research, these are the following upgrades, after some very good advice from CR TURBOS, ASHLEY LANE, NEW MILTON, HAMPSHIRE, BH25 5AQ, 01425 638426 (
http://www.crturbos.co.uk) to whom I paid a visit, after reading about them in a magazine and living only 18 miles away.
These people were true experts and have worked on everything.....marine turbos so large you can stand inside, to tiny little things once used on motorbikes. They have extensive facilities and a warehouse full of refurbished and upgraded items.
I was met by a member of staff, a thoroughly enthusiastic chap with a good sense of humour, who gladly gave me an extended lecture, showing me various turbos that had been cut away to reveal the internal working parts, explaining the pros and cons on twin entry, twin scroll, variable vain, ball bearing, hybrid conversions, ceramics etc and dispelling various myths like larger ball bearing turbos being faster to spin up than smaller non bearing turbos (take note!)
He also pointed out that you can either have a turbo that can spin sooner, giving you early power, which is then limited because it can only spin so fast until it reaches it's limit, or have one that comes on later, but can deliver more power because its maximum spinning matches the higher engine rpm....but you can't have both. The modern turbo systems try for a compromise and use complicated technology (variable vain, twin scroll) and ceramics which go for lighter internal parts for quicker off the mark spinning, but all this can add up to reliability issues.
Also, the bigger the turbo to the smaller the engine equals the bigger the lag (time taken for the turbo to engage). Therefore, the existing smaller IHI turbo for our cars was a perfect match and with just a few internal modifications, "could perform better and with more power".
At this point he showed me a cut away IHI used on our cars......two propellers joined by a steel rod, the left hand propeller was to be slightly enlarged (the compressor wheel) and surrounding casing to be hollowed out to accommodate it, followed by the waste gate TO BE ENLARGENED TO THE GREATEST POSSIBLE DIAMETER THAT THE HOUSING WOULD ALLOW, even to the point of fitting a larger washer to cover it, forget about the 20mm I have read about on this site! The steel rod joining the two propellers ran through some seals, would also be uprated and the mechanism that closes the waste gate would also be upgraded to "make it snap shut for instant response". The whole set up would then be balanced, with the outer casing to be blasted and painted.
According to my mechanic, who took the turbo off and delivered it to them, it came back as a completely new item and the waste gate was "massive!" although the original cover washer had been kept, the hole had been tapered as it passed through the metal casing. Unfortunately I can't show you any pictures or dimensions, but you won't be able to do the turbo work yourself anyway because of the specialist equipment needed....just send it to them!
CR Turbos also recommended my mechanic, READ PERFORMACE, (
http://www.readperformance.co.uk)
12E Queensway
New Milton
Hampshire
BH25 5NN
Tel: 01425 619765
......who undertook all the work. These guys were located about 2 miles from them and once again had a real 'can do' attitude, true perfectionists, often modifying already modified parts to improve them even further and spend a lot of time researching any problems they are not fully familiar with to be absolutely sure, at no extra cost. They build everything from 1000 bhp racing cars to custom exhausts and full engine mapping and test facilities. They thoroughly test all aspects of any modifications and will spend time talking you through everything.....really impressive people who care.
To start with, they did a rolling road test to see what BHP was already available with my current set up (re above).
So, they removed and refit the modified turbo (now classed as a 'hybrid') without any problems, removed the existing air filter and replaced it with the custom built item from Top End Performance (USA) with an open K&N air filter, removed the Quicksilver exhaust and replaced it with a 2.5 inch Piper with dual silencers and PCE (the turbo guys recommended the larger diameter exhaust, when I told them what was available). It has been said many times on this site before and just to confirm, Niel described the Piper as a very high quality piece of engineering, a perfect (if a little difficult to fit) item. Further more, the PCE was worth the extra money, even though my car does not have a Cat. as it further improves air flow over the conventional system. The rear oval pipe centres the hole in the rear bumper perfectly and ground clearance is better than the 2" Quicksilver. Brilliant.
Next comes the remap. Niel's advice on mapping is that each and every car is individual and requires its very own map, one reason why he doesn't like generic maps. I told him about the mountain chips and he was very sceptical, but I had bought an Everest for use with the previous Quicksilver exhaust, so he agreed to give it a try and test it........BINGO!
Once again, full marks to ESM Mountain chips.....the testing showed a "near perfect delivery of fuel" and "good power curve"....." this guy has really done his homework!"
And it wasn't even designed for this system. Niel then did a service, new oil (Castrol Edge 10/60) and standard spark plugs, he doesn't believe in ultra expensive spark plugs, coil paks, HT leads as he has analysed all these items on the rolling road and has never had better performance figures, so "don't waste your money, it's just a money making game!"
Driving Impressions.
It's about now that I would use words like superb and outstanding, but that would be an injustice. What springs to mind is unbelievable, gob smacked or even bloody hell!
I started the engine from cold, turned over once and settled into a perfect idle, the Piper twin silenced exhaust growling purposefully giving a deep throaty note, just like a sports car should sound, without the anti social ridiculous loudness of some of the systems I've heard, on other cars.
Niel warned me to "take it easy until the brakes have bedded in" (he also fitted the AP Racing calipers kit from BG Developments)
So I kept it below 3500rpm to warm the engine and until I reached the dual carriage way where I could see how well it performed safely and after 10 careful miles and an empty road ahead decided to see what it would do.
Even before the turbo engages there is a clear increase in performance, but onced floored.......lit up and took off like a guided missile. I was pressed progressively harder and harder into the seat as the revs climbed towards the red line, with the power steadily and rapidly increasing, changed gear fast, back on the gas with instantaneous power coming back on, NO LAG WHATSOVER, like a 3L had been squashed in there.... absolutely unbelievable! Still hard on the gas, even harder back into the seat, gripping the wheel and holding on for dear life, gear change, back on the gas, INSTANTANEOUS POWER, then fourth, then fifth, all seamless and immediate. I won't even tell you the speeds I reached for fear of incriminating myself!
Furthermore, there is a complete absence of torque steer, ABSOLUTELY NONE WHATSOEVER! I can go from idle to red line, standing start or rolling, as hard on the acceleration as possible and steer with the tip of my right hand index finger to keep it in a straight line! It is as totally neutral as it was when it was stock!
Also, because the available bhp is not massively over the top, you can use every single one of them, the power goes straight down on the road with no wheel spin in a straight line or under steer when accelerating hard out of a mid corner (all testing conducted on a dry surface).
And there's more!.......the paperwork shows 245 bhp at the flywheel, 220 at the wheels, but several things can be improved.
Firstly the Everest chip, although very good, apparently boosts to 0.84 bar and over fuells at the upper rev range, a custom map could see better fuelling and certainly raise the boost pressure. Also, a custom built down pipe running directly from the turbo into the exhaust is currently underway.These improvements could see around 260+.
Having now road tested it for 800 miles.....the fuel economy appears unchanged. Before i was getting 300 miles to a full tank of mixed driving and it's still the same, if any, now it appears to be 330 miles!
Negatives.
There's always something to complain about!
Firstly, would be the exhaust noise. The Piper is superb and on starting and short journeys is actually just the ticket for our car's character. But on long journeys with the roof down, it can become tiring with a constant 'booming' in your ears (it's not over loud, but it does get in your head!) and is worse when the engine is under load, for example trawling up a long shallow incline, but to put it in perspective, on motorways at 70 mph, roof down, windows up and wind deflector in place, the wind rush drowns out the exhaust noise...it is actually most noticeable between 30 and 60 mph, especially when driving next to a high hedge or long wall!
Maybe the 2.25 inch may be a better choice, with a possible slight decrease in BHP....may be worth it, or failing that, er, don't drive a sports car!
Secondly, is the noise when changing gear.......a fairly loud chattering and whoosh sound (like a toned down dump valve) which, I imagine, would be the large waste gate doing its thing. Could be too boy racerish for those who want total refinement, although I have actually come to enjoy it!
Costs
Modification of existing IHI Turbo £405 ( including VAT but not postage as we delivered and picked up)
Custom made air filter pipe and K&N open filter £180 (from the USA.....got hit by import duty) This item is probably not even necessary.
2.5" Piper exhaust with PCE £495 (includes VAT and postage)
Everest mountain chip £100 (includes VAT and postage)
Total £1180 or £1000 using the standard filter, the upgraded item is probably only responsible for around 5BHP and the jury is still out as to whether it is a good thing to be taking the hotter air from the engine bay rather than the cooler air from the original design.
I would even imagine this could be done even cheaper using the single silenced 2.25 exhaust, without the PCE (£287.50), standard filter and Elysium chip, which as I understand raises the boost pressure higher than the Everest, which would make up for the slight loss of flow, so you could be looking at around £800 in total.
Labour would be extra, I can't give you the price form my mechanics because the bill included a lot of other work necessary to fit the B G Brake kit (£1400 for a 'custom made' kit that gave several problems to fit, which I personally think is unforgivable) so I can't dissect it. However, Read Performance charge £45 per hour and I will personally now only ever use them in future.
NOTE: I was informed by Niel that there is a large black pipe in the rear right hand side of the engine bay made of rubber/silicone which passes to the right side to the bodywork which apparently expands under pressure when pushing hard. It hasn't given any problems yet, but is worth replacing just in case. The same people who supply the air filter do a metal version of it (although they include a release valve) so this may need to be added to the price.
Conclusion.
There are people on this site who have created far greater power gains than this, using larger turbos. But what makes this particular upgrade so good is not just the extra power, which is hugely faster than stock, every hp is usable and it is delivered perfectly. The seamless integration from off to on turbo and immediate power at higher revs, total lack of lag, torque steer and continued use of original parts keeps the civility and easy driving of the stock car. The original clutch seems up to the job (I don’t know how long it will last, but it does not slip at all even under maximum acceleration) so no hard clutch and no wheel spin (only driven on dry road conditions and haven't red lined and dropped the clutch on standing starts.....you don't need to, that just wastes the power!).
In fact, for all of you who will need to port your waste gate to accommodate a larger bore exhaust because of boost creep, it is almost silly not have this work done at this price, as the hardest part of this job is removing the turbo, which you will have to do anyway, and you will have a totally refurbished turbo, with a years garantee!
Having said all this, it is anyone guess as to how long the stock engine/gearbox internals will last.
Another addition made were 15mm wheel spacers, front and rear, necessary as part of the brake upgrade, which makes a suprisingly good improvement to road holding and appearance (15" seven spoke originals, which I personally really like, now fill the wheel arches better and higher cornering speeds)
With the correct suspension package (COME ON BOB BROWN!) and some super sticky tyres, this car will be (already is) outstanding, easily better than even the most modern high performance hatches and I've driven most of them!
I also contacted several members about the Quaife LSD who have had them fitted and the unanimous response (thank you all) was that it is totally unnecessary, unless you want to go racing. One member, who races his car, actually said it was counter productive, as on an uneven road surface, the power gets transferred from wheel to wheel and pulls the car all over the road.
So, for a VERY fast, predictable and civil road car (noise not withstanding) at a reasonable price, this is your upgrade, I am surprised that nobody here hasn't tried this already!
Finally, you MUST upgrade the brakes (it's been said many times before!) When I had the Quicksilver fitted I also had Greenstuff pads front and rear, with Greenstuff slotted and dimpled discs up front and stainless steel braided hoses. This gave better (maybe 15%) stopping power over the original brakes, but is nowhere near good enough for this new set up.
As soon as I have the further improvements mentioned above (custom map and down pipe) I'll report back (if you're interested and haven't fallen asleep by now!) but at the moment I'm having Dave's short shift and S2 cables fitted.
P.s, could anybody lend me an Elysium mountain chip? (V4, 13th vin no.1, British SE non cat) It would be interesting to see what BHP would be available on testing, as I understand this chip fuels slightly differently and increases the boost pressure still further. This could negate the need for a custom map (which can be quite expensive) and at the moment the ESM chips do not seem to be available (shop closed on the site).
