HEATING VALVE
HEATING VALVE
Postby 2speed73 » Tue 28.09.2010, 17:00
My eathing valve is broke, another problem...
I know it's the some of Volvo 740/940 and Jaguar Xj6, there are other european vehicles compatibles?
Elan Turbo '91 +Mercedes SL r129 '91
HOTEL FIUMICINO AIRPORT/ROME/ITALY: http://WWW.HOTELRIVIERAFIUMICINO.COM
FACEBOOK: http://www.facebook.com/home.php#!/page ... 7486490562
2speed73
Re: HEATING VALVE
Postby chris.t » Tue 28.09.2010, 17:16
wasn't Mr Smith having something to do with these valves recently?
eta/ Here yer go
Re: HEATING VALVE
Postby baldyash » Sat 12.02.2011, 16:51
My heater works--- now Volvo part fitted. Ye Ha! :D It was a bit cold Monday with the hood down & very little heat
baldyash
Re: HEATING VALVE
Postby GeoffSmith » Sat 12.02.2011, 17:59
chris.t wrote:wasn't Mr Smith having something to do with these valves recently?
eta/ Here yer go
Correct and it's all on the WikiLEC.
Still 10GBP + VAT & postage.
Re: HEATING VALVE
Postby Specky » Sun 13.02.2011, 09:57
Oh no it's not..... :-D
What about Lotus using the Holden Commodore for trial and development work on the environmental control system. Or basically.... we'll just use that heater controller, that tap, that blower...
See eBay item No 120399250426
Or am I just being a geek.....
Re: HEATING VALVE
Postby GeoffSmith » Sun 13.02.2011, 13:11
Oh yes it is! 8) I did it myself as you obviously couldn't be arsed to, you specky geek. :twisted:
Re: HEATING VALVE
Postby wayne » Tue 22.03.2011, 20:27
Having a bit of free time today and suspecting my cars coolant system was just filled with water I finally decided to do coolant flush plus recirculation pump, CTS and thermostat replacement..
I noticed that there was no hot air coming from the car vents (not normally needed here so I guess I never checked it before)!
Heater valve looked like this... :shock:
(207.45 KiB) Not downloaded yet
After referencing the wiki and ordering a new 1 from breydon motors and being curious to the look of the "origional valve" shown I wondered if mine had been replaced with a non standard unit??
Wanting to get the car back together and not wait a few weeks for the Uk order thought I'd search locally for a new valve and came up with this.
(231.9 KiB) Not downloaded yet
AC delco part # 12515169 not sure which other car it is fitted to but although it looks different it fits and works fine :D
Doing a search for the part # I came up with http://www.autopartsdeal.com/Parts_List ... aguar/xj6/
It shows an identical valve to what I removed as well as the part I fitted
Jag XJ6.jpg (5.36 KiB) Viewed 2978 times
I guess main reason for the post is to help people outside of the Uk who need an alternative solution...
Hope the info is usefull to someone
Wayne
http://www.elanm100.com
wayne
