Since the cars been off the road its had a low mileage transplant engine,, new S2 steering rack,, Kuching Roll Hoops and various bits n bobs also removed all the rust repainted and waxoyl ready for another 20
yrs| Home | WikiLEC | Repairs | Upgrades | Gallery | Buy & Sell | Mountain Chips | Meets & Events | Contact |
yrs
kenich wrote:That looks really smart. Engine bay looks pukka toVery jealous of your roll hoops
See you at Castle Combe?
HJ2 wrote:Very nice!
Now tell us... how did it feel to take her for a spin again?!
GeoffSmith wrote::agree: See you at Castle Combe?
racerstev wrote:Wow, it looks great!!
How does it handle with those wheels? Do you notice a difference with the offset?
surfboardfiller wrote:Engine bay looks awesome Trig, also like yout garage, quite a rare thing in Bristol!
trig wrote:One thing I noticed wile driving home is I still have fuel-cut even after porting the waste-gate :?
saska wrote:trig wrote:One thing I noticed wile driving home is I still have fuel-cut even after porting the waste-gate
trig I'd check the following:
1. There is a short hose from the wastegate actuator valve to a metal tube from the turbine side of the turbo. There is a much longer pipe from the metal tube to the Boost Frequency Control Valve (to the rear of the air filter trash can). Check both these hoses do not have leaks / are tightly secured.
2. Doubt it is a problem since you ported the wastegate but check the wastegate isn't either sticking or not fully opening. Even though it is a pain, I prefer to remove the 3 screws and really exercise the wastegate. The bottom of the 3 little screws is a bugger but you can get it in/out by putting your right hand down the right side and then left under all the piping/hoses back to the wastegate. It's that or find an 8 yr old with tiny paws.
3. Do an ElanScan and lets have a look and see what's happening.
4. It may just be that the freeflow exhaust is the cause (flowing too well) and there isn't much you can do except maybe crimp a pipe slightly until it stops.
It ain't all bad news though because it's the MAP (connected to the plenum) that's telling the ECU to cut fuel, so all the pipework from the turbo going to the plenum and all the myriad other pipes connected to the plenum must be good or the plenum would be losing pressure and the MAP would then be reading low and the ECU wouldn't be cutting the fuel.
trig wrote:saska wrote:trig wrote:One thing I noticed wile driving home is I still have fuel-cut even after porting the waste-gate
Thanks saska I will do all the above, apart from the Elanscan as I dont have access to one yet
Users browsing this forum: Apple [Bot] and 3 guests
