Now I am no mechanic,
1) Accelerating in the Elan, the turbo boost guage goes about 3/4 of the way up then when I put the clutch out it drops back to the bottom (I should say here I have never owned a turbo charged car before). Is that about right, what it should do? (It certainly does accelerate very well)
2) Having accelerated as 1 above, occasionally there feels what I can only describe as a slight mis-fire, hardly noticeable, but as though it is struggling to accelerate smoothly. What might be the cause of that?
3) Having accelerated as 1 above, the engine management light comes on more often than not, then after about 5 minutes of steady driving goes out until the next time I accelerate rapidly, my limited knowledge makes me think this means the engine is running too rich, or am I way off the mark? (It also comes on if I run the car idling up to running temperature to dry the window from condensation, I assume the condensation will be sorted when the poor old girl doesn't leak aymore when I sort the hood seals). Thought I had better mention the idling thing though.
4) If I then take my foot off the throttle, there is a slight regular popping noise from the exhaust, like a backfire but nowhere near that loud, what might be causing that or is that what it is meant to do?
5) The wheelbolts need replacing, (for cosmetic reasons only as the chrome/shiny finish has gone) I have searched on LEC and the internet, but have no idea what size bolts they should be. Can anyone point me in the right direction for that please? It is a 1992 Elan SE Turbo, 15" original alloys, no brake upgrades.
6) What does OEM stand for
7) I did find a Youtube video of how to do the paperclip thing, which I am sure was a link on here, but cannot find it now, as I think that would help understand the issues, where is the link please?
9) A lambda sensor (O2) sounds like it detects the ammount of oxygen in the exhaust, if the fault code shows that there is a problem with the sensor, is that an easy fix as well, or might the sensor be ok but there is a problem with the fuel mixture?
Hope I haven't posted too much in one go, but we all need to learn so please go easy on me, albeit feel free to take the p**s as I am always up for a good laugh and what goes around, comes around
Many thanks for your time and patience reading this and I look forward to any replies.
