OK first things first. I've done a bit more paint prep. Very few photos as this was hard work.
As you know, after stripping the covers to test fit the roll hoops, I discovered more rust in a place Norman had warned me to look, but I had misunderstood and checked thoroughly with lights from the underside. From the top, the offside B-pillar rear looked like this:
I attacked it with a stanley blade scraper and this came out!!!!
Access is very limited and even more so on the nearside which is obstructed by fuel tank gubbins - but the nearside of this car has always been better than the drivers side and some rummaging turned up nothing like this. On the offside, I banged with a long screwdriver and pushed with my fingers but structurally it all seems as solid as these tests can detect. So I scraped as much as I could away with the stanley, sanded with a block, and hoovered it all out. Then I doused it in the last of my Dintrol RC900. Time constraints meant no ML into the access holes but they will still be accessible after spray.
I also took the time while the tonneau cover was off, to repair this fibreglass "chip" (McCain wish they could do chips like these):
I missed my spray slot due to other commitments, so Monday I tidied tools mainly, removed the roll hoops, but Mon/Tue/Wed were mainly taken up fitting a new brake kit to my Audi and refurbishing the wheel arches, callipers etc as I went.
The other big job was to try and remove the aerial pre-spray (apparently there is a keyring style tool in the toolkit, I haven't had chance to look and can't now) and test fit the sharks' fin, and to remove the rubber spoiler.
This was a nightmare. I've been dousing the rusted screws in Plusgas for a week, and after trying impact screwdrivers (being gentle because the fibreglass is not secure enough to push against), drilling out the screws, complicated clamp arrangements, breaker bars, etc etc I ended up using a Stanley to cut away the rubber, an air chisel to break it out under the washer and then to break the washer from the screw, following which a 10mm stud removal tool on an air ratchet was enough to grab the screw head and remove it - I only broke one of the holes open and its an easy repair. But this was 5-6 hours total work; once the method was established I sorted it in under an hour....
And then today -
Maiden voyage complete. A trailer wasn't possible, so I booked an MOT at a friendly garage down the road and drove her home - 20 miles.
Because I have all the insulation/covers/carpets out, you can hear right through to the wheels - lucky, because the back nearside caliper/disc is rubbing badly. This confirms I'll have to replace all 4 calipers not just the fronts (although the rears passed MOT they have sat for a year and likely seized in part). I do not look forward to making the HiSpec kit from PNM work on the rears, PNM themselves seem great but I've heard some horror stories about bad engagement on the handbrake front from the HiSpecs - but this is what I will have to do, because I have HiSpec fronts.
I wasn't too gallus driving her but I did let the turbo engage on the final stretch and took a corner I'd do at 40 in the Audi (4WD) at over 60 - she's just glued to the road. Absolutely glorious.
The main problem I notice is that when moving off from a standstill, especially when trying to pull up a ramp, or a kerb, or over a bump - the car almost stalls. i.e. when reversing into a parking space with a 2cm kerb, the car really struggles to pull over it without a bit of throttle; equally if the car was left to try and 'drive itself' in 2nd gear with no accelerator, it might struggle a bit or stall.
Thoughts I have
- throttle needs tightened (but it idles over 1000)
- vacuum issue quite possible
- EGR issue related to vacuum pipes or solenoid
- poor electric, loose earth (you see the battery power gauge drop and lights dim under this circumstance)
