Hi
DISCLAIMER: This is based on my experience with ONE 20 year old Lotus ELAN, which may have had any number of undocumented changes done to it.... your mileage may differ
Now, despite their being two types of soft tops being made, my belief/experience is that most of the original (characterised by the vertical drainage strip along the falling pillars being straight down) have probably all been replaced by the newer design as it provided a stronger design.... AS FAR AS I CAN DISCOVER, THE ONLY DIFFERENCE BETWEEN THE TWO DESIGNS WAS THE IMPROVED DRAINAGE AT THE REAR! So, it was therefore very easy to replace the softtop material just using one-size-fits-all. Note, I am only talking about the actual soft-top material here.
Now, there was also a change in the header seal / header seal rail between the two models. AS FAR AS I CAN SEE, BOTH HEADER SEALS CAN BE FITTED TO EITHER FRAME/ROOF!
The caveat here is that one should use a matching header seal and header seal railing.
I received a pre-8161 header seal, and it didn't fit my header seal rail, so I ASSUME that my header seal rail is from post 8161
If you look at this picture of the older header seal,
pre-8161 header sealyou will see that there is a recess in the rubber where the header seal rail fits into it. The picture shows that this recess is cut at an angle of about 45 degrees (in fact, I have had to splay the side of the header seal out in order to even get the header seal rail on to it)... this picture does show the header seal rail, and shows its end as being cut at 90 degrees. The next picture may show this better
post-8161 type header railAs the header seal was checked by SJMotors, and they are sure they supplied the early model, I assume that the header rail with the 90 degree cut is the later model, and that it requires the later header seal.... BUT, I have never seen the later header seal, so cant be sure
SO, to sumarise... Have a look at your header rail. If it has 90 degree end, then you are lucky... it should be for the later model header seal (which is cheaper, more available, and probably newer manufactured date)
NOW, all I did to get my 'old' seal to fit on my 'presumably new' header rail was to cut the header rail at the required angle to match the shape of the recess in the header seal (I also had to make it a bit shorter.. but only a few mm).
From my experience though, it may be difficult to make it work the other way... because of the angle of recess etcetera, it may not be possible to put a later seal onto the earlier header rail! At least, it may fit, but it may also leak as the header rail may be too short.... BUT REMEMBER, I HAVE NEVER HAD THIS COMBINATION TO BE ABLE TO CHECK IT
Before ordering, it may be an idea to ask for a photo of the seal, so you can check it against your header rail
Hope this helps
Good luck
Dave (enjoying having brakes that work after fitting a complete set of PNM/Hispecs front and back)
