by Piperman » Fri 20.11.2015, 17:07
Hi all is there any other reason which causes the engine to cut when boost builds up ,i have checked waste gate which is free Derek
by Rice crispy » Fri 20.11.2015, 17:39
My two penneth worth
1) Is there a leak from the inner wing to inlet manifold as this could cause overboost
2) Have you a larger exhaust? if the wastegate isn't ported can cause this and colder weather could bring it out so I understand.
3) Is a boost valve fitted ? has it been adjusted by accident allowing overboost
4) Are you sure the wastegate fully opens?
Rice crispy
by Fredjohn » Fri 20.11.2015, 22:23
What are the engine revs when the motor cuts?
Hi boost generally = hi revs, so you may be hitting the rev limiter.
by Piperman » Sat 21.11.2015, 00:45
Hi Dave & God I've made sure waste gate has total movement ,rev wise with boost kicking in approx 4to5000 its like hitting a wall will check out other suggestions thanks Derek
by Rice crispy » Sat 21.11.2015, 10:02
Does the engine check light flash forward few seconds immediately after it happens? and have you got any fault codes?
Rice crispy
by Enright » Sat 21.11.2015, 10:07
Neil
- Modificator
by Piperman » Sat 21.11.2015, 14:38
Thanks everyone for replies i now have full rev range guess it was a blip i rechecked the waste gate ,took off accutator perhaps it had a stiky spot , i now have hypadrive as aposed to impulse power !
Return to Engine
