Help ! VSS and EST Monitor error
Postby Axel-F » Wed 03.02.2016, 09:49
Dear all,
I am submitting this request for a friend M100 driver, we need your help !
After usualy around 20mn driving, when releasing the accelerator, check engine light turn on, and engine rev is limited to 3 800 rpm.
Need to stop and restart the engine to exit safe mode (rev limited to 3 800rpm).
An elanscan has been ran, and show 2 faults codes :
- VSS : and as a mater of fact, the scan didn't record any speed during recording (despite very fast drive !)
- EST Monitor error.
Here is the scan :
M100 Gerarld.zip
What is surprising is that VSS has just been changed ( same for MAP)...
Any help is welcomed !!
Axel-F
Re: Help ! VSS and EST Monitor error
Postby Giniw » Wed 03.02.2016, 12:48
Hello,
Have you searched in the engine management manual? There are usually the voltage one is expected to measure on the sensors.
Giniw
Postby Axel-F » Wed 03.02.2016, 15:29
Giniw wrote:Hello,
You mean checking voltage to ensure VSS is not damaged ? Shouldn't be easy, cause need to do it while driving... isn't it ?
Axel-F
Postby Giniw » Wed 03.02.2016, 16:06
That is not easy indeed ... Maybe on a bridge?
But with a square wave signal it will not be easy anyway ... unless you have an oscilloscope :(
What is the lower code of the VSS and EST? The workshop manual tells to address the lower code first when multiple error codes are reported.
Giniw
Postby Simon_P » Wed 03.02.2016, 19:41
EMK4 - 42 tells you how to test the VSS.
Postby Axel-F » Wed 03.02.2016, 21:29
Simon_P wrote:EMK4 - 42 tells you how to test the VSS.
Yes thanks ! 42 is for EST, VSS is 24, but it should help to do some testing !
Axel-F
Postby Fredjohn » Wed 03.02.2016, 22:32
I think you may have misunderstood Simon's comment.
He is suggesting you look at the Workshop Engine Management Manual and read section EMK4 Page 42 (and 43). These pages tell you how to diagnose and test.
Similarly EST code 42 information is shown in Section EMK4 Page 52 and 53 in the same manual.
Hope this helps.
Postby Simon_P » Wed 03.02.2016, 23:05
Sorry - Not clearly explained - Thanks Fred
Axel,
EMK4 page 42 describes how to test the VSS with the wheels in the air and the engine switched off.
Before doing anything check the base timing and set the idle - These are reference points if you haven't checked them you are guessing.
i did look at your scan but the EST and VSS flags were set before you started the scan.
Postby Axel-F » Wed 03.02.2016, 23:36
Simon_P wrote:Sorry - Not clearly explained - Thanks Fred
Axel,
Ok, understand, EMK4 code 24 is page 42, we are aligned ! :wink:
Thanks !
Axel-F
Postby GeoffSmith » Thu 04.02.2016, 00:54
No speed output at all indicates a VSS signal is not getting to the ECU. I would do as the manual says (but in the reverse order ) and check the output of the VSS then the input to the ECU.
PS Why was the VSS replaced Axel?
Postby Axel-F » Thu 04.02.2016, 15:35
GeoffSmith wrote:...
To try to solve the fault code 24 "VSS"... but it didn't work !
Axel-F
Postby GeoffSmith » Thu 04.02.2016, 16:24
That's what I suspected hence the suggestion to make sure it is working then following the signal through to the ECU.
Can you confirm that the CEL lights (as it is on a common supply to the VSS)?
Postby Axel-F » Thu 04.02.2016, 19:24
GeoffSmith wrote:'...
From what I understand :
- fault code 24 (flag 0) and 42 (flag 8 ) are read "on" by elanscan
- elanscan does not read any speed, despite car is obviously driving (fast)
- CEL does only lights from time to time, usually after several minutes driving, and when releasing the accelerator, then the engine is in safe mode ( turning off the engine reset the safe mode)
From the scan provided above, fault code 24 & 42 are on, but CEL didn't lights ( this time...)
Axel-F
Postby GeoffSmith » Thu 04.02.2016, 19:41
Axel, the reason I asked if the CEL was lighting was because the CEL light is shown with the same supply as the VSS.
http://wikilec.9600.org/images/1/1e/MJ2 ... rbo%29.gif
Note: Ignore the above as I've just realised that the supply is common throughout the instrument panel. :oops:
http://wikilec.9600.org/images/9/99/MJ2 ... uments.gif
Return to ElanScan
