Brit-Car-Nut wrote:I looked through a lot of parts books and found the throttle body on the M100 is from the 1987 Isuzu I-Mark Turbo and the TPS that is shown for it looks like the one used in the M100.
The TPS for the '91 Isuzu Impulse Turbo is not the same as the one used in the M100.
The 1987 Chevrolet Spectrum Turbo also uses the same part.
The numbers offered are: TH277 by Standard, 8944331860 and 94433186 from Isuzu and GM, SERA4848 is the Hitachi part number for the Th277.
AC Delco used number 2134486 or 19236540.
The GM and Isuzu numbers are all shown to be obsolete.
I ordered a SERA4848 and will let everyone know if it really is a correct match
Brit-Car-Nut wrote:The story so far:
The TH277 Throttle Position Sensor finally arrived and the actual sensor is probably fine but the attaching wings are a lot longer than ours and it doesn't have a harness because it was used with a plug in connector.
The TH277 is a Hitachi SERA484-8 while our TPS is a SERA484-2
So, I went back into the catalogs and under the Isuzu I-Mark TURBO in 1989 there is a listing for a Standard Motor Products TH332 which cross references to TPS4085 and Airtex Wells # 5S5200. It supposedly also fits the Chevy Spectrum Turbo.
The TH332 is a Hitachi SERA484-2a and it looks to be identical to ours.
The TH332, TPS4085 and the 5S5200 are not inexpensive at Rock Auto $195.99 for the TH332 or $189.79 for the 5S5200 but a sight less expensive than the Lotus A100E6432S at £237.88
I found suppliers on eBay, Google, NAPA, Auto Zone and Amazon. Auto Zone seems to have one of the lowest price in the US at $174.99 - It is a Special Order Item so don't expect to walk in and pick one up.
Amazon has a listing for $167.76 and free shipping.
There is a reference to Isuzu part numbers 8943146060, 8943607820 (GM # 94314606 and 94360782).
So, NEW TPS units are still available from Lotus, Rock Auto, Auto Zone and Amazon and the TH277 is probably the correct electronics, jut the wrong attachment and connection, but it is a 4 wire device. The one I purchased was only $50.00 so not a big waste in the overall scheme of research. If anyone wants it, they can buy it from me for $50.00 + whatever the shipping to your address will cost. I will eventually sell it on eBay.
I hope this info helps.
Brit-Car-Nut wrote:SJ's price is no worse than the US versions. YOu should probably go that route
Scott wrote:Brit-Car-Nut wrote:SJ's price is no worse than the US versions. YOu should probably go that route
Ok cool! I'm buying next week!
Does anyone know if the car is shaking at high speeds ( >80-100km ++ ) what could it be?
muley wrote:Scott wrote:Brit-Car-Nut wrote:SJ's price is no worse than the US versions. YOu should probably go that route
Buckled/out of balance wheel?
Fredjohn wrote: Toyo Proxes T1R in case you want to know!
sorry guys.rob/d wrote:Hey Matt .
Do you have a linky for that TPS from china ?
I suspect mine is faulty as i am super rich on tickover , but it has gradualy got there over a few MOT's , so i now suspect the throttle sensor .
Testing it tomorrow , but if there's a cheap version available , i might just swap it anyway .
Is it this ?
Looks correct .
https://www.aliexpress.com/item/1005007 ... ry_from%3A
Thanks Matt .
