Lotus Aftersales Parts List - Newest Version
Re: Lotus Aftersales Parts List - Newest Version
Postby Brit-Car-Nut » Sun 24.07.2016, 12:53
Jamie N has been making replacement "A" Pillar and window surround seals and recently announced a combined "A" Pillar/Header seal assembly would be available.
All of the others will need to be patched or repaired using whatever rubber material you find that will help.
Postby Scott » Tue 26.07.2016, 05:29
Brit-Car-Nut wrote:Jamie N has been making replacement "A" Pillar and window surround seals and recently announced a combined "A" Pillar/Header seal assembly would be available.
R u sure about that? Last talk, Jamie said that he quited this in general and has only one A pillar left..
1998 BMW 316 E36 Coupe
2001 Volvo S40 1.6
1991 Lotus Elan M100 Turbo
2004 Ducati Monster 620ie
Scott
Postby Brit-Car-Nut » Tue 26.07.2016, 13:45
I can only state what was in recent posts. If Jamie says he has ceased, then he would know. You can still get Original "A" Pillar seals from Lotus but none of the other seals are now available.
Postby Brit-Car-Nut » Tue 03.01.2017, 19:05
Just received the newest price list. I have updated the listings and now you all can see the part numbers and prices still available.
These lists are for ALL models so you will need to look at them knowing the M100 uses mostly "100" parts, but some parts (like the OZ hub caps A082G6071F) are from other cars, so best to research what you are needing and look at the list to see if your part is on the list.
Current List in PDF Format
Current List in EXCEL Format
All Lists in both formats
The lists are also available from my main website: http://www.lotusm100.com
Postby Scott » Tue 03.01.2017, 20:54
So if we need a part from this list where we place the order?
Also how can we order the short stick shift kit?
2001 Volvo S40 1.6
Scott
Postby Brit-Car-Nut » Tue 03.01.2017, 21:34
You must place an order with a Lotus Dealer. I know all UK dealers participate but US dealers do not. I don't know if other EU dealers honor the prices.
I only sell short shift kits for/with my matching cables or if someone has a set of Bob B.'s cables, I can make up a kit for them too.
Postby Scott » Wed 04.01.2017, 06:21
Brit-Car-Nut wrote:You must place an order with a Lotus Dealer. I know all UK dealers participate but US dealers do not. I don't know if other EU dealers honor the prices.
Yes i want the full kit including the cables too. Could i order it from you? Send me a pm with prices etc please. I live in Athens-Greece and i have a turbo LHD m100 (1991)
2001 Volvo S40 1.6
Scott
Postby Fredjohn » Wed 04.01.2017, 08:07
Scott
Click on the green link at the bottom of BCN's post and go to page 9. You will see the latest prices June 2016 there. :-)
Postby Brit-Car-Nut » Thu 07.09.2017, 15:26
Finally got a price book version I could use to grab the newest Special Parts Prices.
Lists, Manuals and Guides are also available from my main website: http://www.lotusm100.com/manuals
Postby lotustonybassplayer » Thu 07.09.2017, 16:48
Hi John the links are not set up correctly :(
lotustonybassplayer
Postby Brit-Car-Nut » Thu 07.09.2017, 21:22
lotustonybassplayer wrote:Hi John the links are not set up correctly :(
Sorry, Fixed.
Postby Brit-Car-Nut » Thu 01.02.2018, 15:34
Front Left caliper.
Postby stevieg8571 » Mon 26.02.2018, 19:11
If anyone was hoping to get B100J6001F Front LH caliper from the aftersales list, they've all gone, and guess what I need.
stevieg8571
Postby Brit-Car-Nut » Mon 26.02.2018, 19:27
SJ has them listed at £99.17 (and probably bought up all stock from Lotus) - you can't blame them
Compare that to $361.96 from Dave Bean in the US.
Look at this link for an alternative: viewtopic.php?f=41&t=26131&p=331901#p331901
Postby simonbuk » Wed 31.10.2018, 21:16
So can you buy from this parts list direct from Lotus ? Haven't found anywhere that suggests I can.......yet.....
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Brit-Car-Nut » Wed 31.10.2018, 21:25
NO, you order from your local Lotus Dealer. I use Stratton Motors in Norfolk, but any Lotus Dealer will get you the parts for the prices I post.
I believe the last list is dated July as I haven't gotten around to filtering the most recent price book.
I just updated the lists to include October 2018 (the newest I have)
Postby stevieg8571 » Wed 31.10.2018, 23:37
Are the above lists, dated October 2018, showing parts that are available now? I ask because when I called my
nearest dealer regarding the front LH calipers I was told they'd all already gone, or have they made more available
Thanks, Steve
stevieg8571
Postby Brit-Car-Nut » Thu 01.11.2018, 02:08
The list is only the parts Lotus is liquidating.
Looking up B100J6001F on DeRoure has this description:
Table Number: 33_01a
Position: 001
Part Number: B100J6001F
Description: Brake Caliper Assembly, front, LH
Notes: includes brake pads
Qty on Car: 1
Price (each): £104.09
Condition: New
Stock: Factory Order
Exchange. £50 to be refunded on receipt of exchange item
The list is 30 days old. Maybe one of the dealers (SJs or SW Lotus, Bell & Colvill) come to mind) bought out the remaining lot and is now offering them on an exchange / rebuilt basis.
When I see something interesting on the list, I call my dealer right away and check stock and usually buy one or two of the part I thought would be useful.
I was told that I got the last pair of A-Pillar seals when I ordered them last month - they were NOT on the Sale List.
Rock Auto has had calipers for the Pontiac LeMans 1989, 2.0L Vented Rotors as cheap as $18.00 + postage These are supposed to be a correct interchange...
https://www.rockauto.com/en/catalog/pon ... liper,1704
Postby Saltire » Thu 01.11.2018, 09:06
I couldn’t source new front calipers from anywhere for my recent brake overhaul, or I’d have fitted them. (The rears were great, thanks John). All the usual sources, including Rock Auto, said sorry, no. I’ve ended up doing a major rebuild on the existing ones, which is not ideal, but way better than rear wheel braking only.
I suspect the only way forward in the future will be an upgrade kit (PNM, Wilwood, etc), which poses significant problems for those of us who want to keep the car as original as possible.
Postby Tuga2112 » Thu 01.11.2018, 09:24
just to clarify,
i can go to a lotus dealer (if such thing can be found) in the UK and order the parts in the list ? or is this list only for UK dealerships ?
Return to Elan Parts for Sale (New Parts For Sale)
