what is this?
what is this?
Postby johnj » Wed 03.06.2020, 20:12
Today I was looking at the rear of the engine bay and came across this
. Has anyone any idea what it is? Should it be connected to something (if so what), should it be capped or left as is?
johnj
Re: what is this?
Postby Brit-Car-Nut » Wed 03.06.2020, 21:28
Looks like a vacuum line with a one-way valve fitted. I don't recognize it though.
Where does the other end go?
The hose looks to be too small for the brake vacuum hose which uses a check valve and it looks to be too big to be the windshield washer hose from the reservoir in the boot which also has a check valve in it.
The US car may not have anything like it...
How about the hose to the MAP sensor #3 in second picture
It also attaches to the fitting #27 in the intake manifold
Click for larger view
OR the other line #2 in this picture:
Re: what is this?
Postby johnj » Wed 03.06.2020, 22:25
I don't know where the other end went because the other end is inside a bundle of cables which disappears through the bulkhead. The cable has a solid wall ie not rubber
johnj
Re: what is this?
Postby Brit-Car-Nut » Wed 03.06.2020, 22:31
That is a hose, not a cable...
Does your MAP sensor (on the RH side of the firewall) have a hose going to the intake manifold?
Does your Carbon Canister have a hose going to the EEC valve on your Left Side inner fender in the engine bay?
Re: what is this?
Postby TorqueHorse » Thu 04.06.2020, 03:35
Ohh Ohh, I think I know this one. Is it the non return valve for the EECS purge line?
'91 FED M100 -rolling resto
Re: what is this?
Postby TorqueHorse » Thu 04.06.2020, 03:48
I actually have the opposite problem where I have about 6" of crumbling hose hanging off the port loose, and I've been looking for your end with the non return valve to reattach. Try tugging on this one and I bet it is loose.
The hose material is something different from a regular vacuum hose (and I'd like to know what so I can replace it).
Re: what is this?
Postby Brit-Car-Nut » Thu 04.06.2020, 04:00
You could be right. That would account for the non-return valve that is in the line.
Judging from the parts book illustration, it is a nylon line with fabric connector segments at both ends.
I can look at my engine(s) tomorrow to confirm that.
Are you sure you don't want to come to North Carolina so you can look at the different parts that make up the M100?
Re: what is this?
Postby Rambo » Thu 04.06.2020, 07:50
It does look very much like the non return valve in the purge line. Looks like the other end should go to the EECS purge port
Re: what is this?
Postby johnj » Thu 04.06.2020, 18:30
Thanks all
TorqueHorse Thanks for the photo. When I got the car the engine reved to about 2000rpm on start up before settling back to 1000-1200rpm (it still does it) it was suggested that there was a hose off or split. I found a loose crumbling hose and could see nowhere to fix to ,so I took it off and blanked off the nipple at the back of the plenum. I now know what it is, thank you. As you say the hose is different to the usual hose material, but will it be alright to use a piece of silicon hose to connect the non return valve to the plenum ?
What is EECS?
johnj
Re: what is this?
Postby GeoffSmith » Thu 04.06.2020, 19:12
Evaporative emission control system i.e. purging fuel vapours trapped in the carbon canister.
Re: what is this?
Postby Brit-Car-Nut » Thu 04.06.2020, 19:52
johnj wrote:Thanks all
They used a plastic / nylon main pipe with short pieces of connector hoses to make sure the long hose never "got tired" and started collapsing and stopped doing it's job.
If the hose collapsed, it would block the vacuum leak but the emission component would not work and that was something the developers never wanted to happen because the emission certification might be revoked.
Just find the connection points and put it back into it's proper place.
Re: what is this?
Postby johnj » Thu 04.06.2020, 20:43
I will do that tomorrow.
Again thank you all.
johnj
Re: what is this?
Postby Chrisbrooks » Tue 25.02.2025, 18:14
Hi, I have the same problem but only have the piece from the plenum
I’ve searched the bulkhead for hrs can someone tell me where to look please
Chrisbrooks
Re: what is this?
Postby Simon_P » Sat 01.03.2025, 23:23
TorqueHorse wrote:Ohh Ohh, I think I know this one. Is it the non return valve for the EECS purge line?
See this post - it is the "Purge Line" in the diagram and goes to one of the vac hoses on the back of the plenum by the throttle body.
Users browsing this forum: StuartB and 0 guests
