Glovebox Repair
Glovebox Repair
Postby Simon_P » Wed 05.05.2021, 09:57
The cover has come unstuck.
Has anyone experience of re-glueing it?
It has come completely unstuck so I think that the best approach to repairing is to take the lock out so that I can clamp it up properly. Any advice on how to take the lock out please?
Re: Glovebox Repair
Postby Rambo » Wed 05.05.2021, 11:56
I have done this about 15 years ago Simon but it's so long ago that I've forgotten what I did. But it must have been easy for me to manage it !
The schematic should help though http://wikilec.com/view/Glovebox
Re: Glovebox Repair
Postby alan e » Wed 05.05.2021, 12:00
If you need a cover let me know i got one you can have and i will put it in the boot and give it to you at Castle Combe if you go.
Black 1992 M100
2010 black evora
Austin 7 1932 box saloon
BMW X5
alan e
Re: Glovebox Repair
Postby Dave Eds » Wed 05.05.2021, 13:05
Just slide out No 22 to get the lock off........
Re: Glovebox Repair
Postby TorqueHorse » Wed 05.05.2021, 13:32
The lock is held in place by sandwiching the housing flange on the outside of the glovebox, and a retaining U clip on the inside. There are little retaining nubs at the top of the U, but you can slide the U down and then you should be able to work the whole thing free.
I tried a couple of adhesives and original Gorilla Glue worked best for me. But FWIW I kept the lock in place to help center the cover while regluing. Good luck.
'90 FED M100 -mid resto
Re: Glovebox Repair
Postby dapinky » Wed 05.05.2021, 14:31
I couldn't be arsed to remove the lock (as that was all that was holding mine together), and simply used a length of 3M double sided sticky spongy stuff. Having cleaned the 2 surfaces, sticking it to the actual box was easy, then peel off the green tape and push the cover into place..... it has lasted 10 years so far.
Re: Glovebox Repair
Postby Simon_P » Sun 09.05.2021, 13:20
Thanks for the kind offer Alan - Mine is now fixed.
DaveEds / Rambo / Torquehorse -yes 22 slides off really easily when you know.
Thanks also to the person who pointed me in the direction of the utube video.
I used contact adhesive and a lot of pegs to hold it together.
Return to Interior
