Looking for Magnetic Pick Up part number?
Postby Add_Lightness » Tue 22.02.2022, 20:29
Hello everyone. I have been scouring the internet for the magnetic pick up sensor part number for the M100 and have had zero luck. Reached out to a lotus dealership as well and didn’t have much luck there either. Does anyone happen to have any information whether it be a part number or even a suitable replacement part number? Any help would be greatly appreciated!
Add_Lightness
Re: Looking for Magnetic Pick Up part number?
Postby FunElan » Wed 23.02.2022, 02:43
FunElan
Postby Rambo » Wed 23.02.2022, 08:45
I think these HES's are much cheaper via Lotus Aftersales. ~£20 IIRC??
Postby HJ2 » Wed 23.02.2022, 14:52
If you feel very lucky:
Pry off the conformal coating that hides the tiny PCB
Re-solder all connections
Cover everything in good quality epoxy again.
I fixed 2 like this, the solder joints are dodgy after all these years...
(... or was it the HES?...)
Postby Fredjohn » Wed 23.02.2022, 16:44
All above advice is good. Take your pick!
However, as a semi-direct answer, the parts manual is on this forum in the Manuals section, visible once signed in.
An online parts catalogue is also available at deroure.com.
sjsportscars.co.uk also have a helpful website where you can find most available parts.
Elan S4 DHC 1969
Evora 2010
MB E250 CDi coupe 2013
Boardman Endurance SLR 9.4 disc 2018
Rapido 746 2010
Postby Rocklobster » Wed 22.06.2022, 21:43
Hi, I wondered if you managed to find a replacement part for this as I have the same problem.
Any thoughts or advice appreciated.
Pete
Rocklobster
