CalElan wrote:Pretty embarrassing how long it’s taken me to come back to.. oh well..
Don't apologize - it's only been two years
RonR wrote:I'm no C programmer, so there's probably lots more elegant ways to extract and display the info, but here's one of my efforts - adapted from Matt's original - Abandoned due to lack of support for the display I was using. The data extraction and calculations work though.
matts1972 wrote:CalElan wrote:Pretty embarrassing how long it’s taken me to come back to.. oh well..
CalElan wrote:RonR wrote:I'm no C programmer, so there's probably lots more elegant ways to extract and display the info, but here's one of my efforts - adapted from Matt's original - Abandoned due to lack of support for the display I was using. The data extraction and calculations work though.
Many thanks - I'll download and have a play
'btw I may have spoken to early about it working - I have a file with the correct file extension but it won't open.
Having looked closer, when I turn off the ignition it kills power to the Uno, (actually drops it to about 6v), so I think it's not wrapping up the writing process correctly.
I may have to pull a permanent 12v supply from somewhere to test this theory out..
Unless anyone has a better idea???
CalElan wrote:Thanks so much for your patience.
Checked I had the right version of the sketch and the right library versions
Still no joy - reformatted the sd card and reseated the uno and the logger..
It works and I can open the file!
Brilliant thank you…
Just need to work out the 12v - it’s 12v with the engine running, drops to about 7 with the ignition off. I can always find a better 12v feed if I can’t work this bit out!
CalElan wrote:Just need to work out the 12v - it’s 12v with the engine running, drops to about 7 with the ignition off. I can always find a better 12v feed if I can’t work this bit out!
chrism wrote:Hey matts1972, a wireless ElanScan would be a real bonus
