texas2201 wrote:I've got a similar problem..... well the lurching/stalling bit .... I'm still trying to solve it - I do one thing and it gets better - then it comes back...... going into garage for a smoke test for vacuum leaks and to check the base timing. Now it seems to be over fuelling - flooding - so suspecting one of the injectors is sticking - so they will get checked as well
i've fitted new plugs, coils, VSS, throttle cable, injectors,
dapinky wrote:Martin,
When I changed the TPS on the old red car, the screws were bu66ered - they are a simple M4 setscrew (I cant remember if they were M4, or M5 - but they are a standard thread which I had in a box!), so i just replaced them with 'normal' hex-head ones from the garage shelf and used a small spanner to nip them up.
texas2201 wrote:Garage was very helpful - but it was out of their depth. Did find that the new VSS was loose ..... removed, refitted and tightened. No change to the problem.
Piggy backed a new Temp Sensor and as soon as engine was warm EML came on with a code 21 TPS ..... seems like the bad CTS was "hiding" this before.
Ordered a new TPS from Rockauto and a proper CTS - allegedly arriving Wednesday .... in Portugal from the US ..... we will see
And of course one of the screws on the TPS has been mullered by a previous visitor!!!! New screws and Throttle body gasket (the one fitted is in perfect shape/condition) will be ordered from SJS if the transport price is not offensive. Lost a jubilee clip in the engine bay - will keep looking for it. Bottom hose on TB was spawn of the Devil snap on Clip..... I F**kin hate those - came off in two pieces.... 40 mins of my life I wont get back!!!! so another Jubilee needed.
Fredjohn wrote:VARIABLE speed sensor.
Tuga2112 wrote:sorry for the complete hijack, but i seem to be in trouble with mine (VSS)
and i checked SJ and they only cost about 20 quid. making me wonder if this is a common GM part that is actually available for £8 somewhere else. ?
ive checked wiki, but no entry for the VSS there.
Tuga2112 wrote:seems the calibra instrument panel is a very close match to the elan
https://www.ebay.co.uk/itm/284847215592 ... R4iY95PPYQ
althought a little pricey
