Luvmeadeadpedal wrote:I have searched a bit but not found an exact match (forgive me if I missed it).
I have earlier replaced my alternator on my 1991 and my charge voltage gauge reads right around 14v as it should and does not exhibit any strange behavior when I run the heater fan or turn the headlights on.
The last few times I have driven the car I get an intermittent alternator/ charging light on the dash (you know the idiot light) and I look over at the actual voltage gauge and it looks perfectly fine.
It is not a strong light and sometimes sorts of flickers and then goes away which I think might be related to something other than the actual alternator charging.
Give me your thoughts on this.
thanks
Luvmeadeadpedal wrote:Thank you for the tip on a possible cause.
I do have an O2 sensor and I just had my alternator rebuilt with new parts given I was previously seeing the light + showing low charge voltage on the gauge.
I new see steady 14v even at idle and the lights / heater fan running high so I feel fairly confident that I have the proper juice.
I will do some more searching to see if I can find some sort of a fix.
thanks
Tuga2112 wrote:
TLDR
you can check the voltage at the sensor while its operating (car is running). check if that voltage is within the sensor operating range (id expect anything above 12v is good, but you may find details about the sensor from the manufacturer)
if the voltage is within range, i think you would be fine.
Tuga2112 wrote:It's worth noting that although swapping the regulator is the preferred solution.
A circuit can be made (I think all you need is a relay) and installed in the binnacle that will recognize the alternator output and power the o2 sensor directly from the battery.
I never tried it but it was suggested to me by someone who's very well versed in the m100 electrical system and the theory made 100% sense to me when I looked into it.
