Tuga
I think i know what you're getting at , a vacuum leak would lead to higher pressure (absolute) , Then the ECU would increase fuelling to prevent lean running and this would be faster than the fuel reg. I can see changes in the vacuum on the elanscan traces but trying to match it to the injector duty or width is difficult .
i have tested the MAP with a hand vacuum pump and it responds pretty much as my analogue gauge shows. I have a miniature petrol filter in the MAP line because the original trap was cracked when i got the car . I figured if it was around the same volume as the original any damping effect would be close. At the moment i've removed it as i didn't want it having any affect on my testing.
Ive tightened up all the injector caps terminal grips just to rule these out.
Another test today and set up of the IAC bypass. I have carried out a blocked exhaust test with a vac gauge at 2500revs and it seems OK. I noticed that the O2 sensor doesnt respond initially and the blower casing is around 110c before it starts producing 0.4v. Road test again today and whilst it felt good for the first 5 miles the ECU light came on again at almost the exact same spot on my road trip yesterday. Its got to be a coincidence .
The elanscan trace shows it switching between open and closed loop continuously and then the O2 sensor gives up.
I think im going to try one of the older O2 sensors i have and then if no better swap the injectors back to my cleaned originals . Desperation setting in now
road run after IAC setup.zip
Chas54
