3D - scanned parts library
Postby awaken101 » Mon 09.11.2026, 23:33
Hi all,
Wanted to start up a post to document some things while I take up this new hobby of 3D scanning. The intent is to share with the community the things I've scanned and make them accessible through Thingiverse. The main goal would be more for those who'd want to get exact measurements and/or download a basic 3D model of the things I scan. This way it would make it way more convenient to tweak the components to do something else (i.e. looking at the ashtray insert hole & it's backplate to get specs and create something else for that area).
Only have one item so far but hope to have other smaller interior parts shortly (forgive me I'm new and learning all of this as I go). If you need the dashboard screw cap covers that are middle dash, you can grab the files from my new Thingiverse library located here: THINGIVERSE LINK
Currently Claude is helping me decipher a scan I made of my dashboard and providing me with a fitted tablet shroud to cover over my vents/radio. It's a one off for the tablet I used, but the overall shroud could be modified by others. Doing some test pieces prior to a full build so the shroud fits perfectly, this is both fascinating and frustrating at the same time. :lol:
So I hope in the future add more 3D scans to Thingiverse as well as update here so you all can grab them if need be. If anyone else would like to help contribute to any 3D scanned pieces, I welcome your input and sharing here. Till then, take care everyone!
Steve - '91 Calypso Red FED
awaken101
Re: 3D - scanned parts library
Postby Tuga2112 » Tue 10.11.2026, 09:07
the problem with scanning is the polygon count.
i guessthey will be good enough to reproduce something. but in my case, i have always wanted to modify or create something that fits in the same place. and trying to reduce polygons on a scan is a pointless exercise
Postby awaken101 » Wed 11.11.2026, 22:25
I like coffee and since the M100 has no cup holders, I figured a ball mount somewhere in the car could help me with my caffeine addiction. The ashtray is rarely used in my convertible so it seemed like a good place to affix something in that spot. Found a couple items on Amazon that would help complete this and after putting it all together today it seems to be working out well.
Currently, just the 1" ball mount is secured with a 1/4" 20 threaded bolt and it's somewhat secured properly. Could be better, I'm worried that once out on the road the vibration may 1) move the thread of the 1" ball mount from behind 2) weight could potential unseat the insert from the opening.
I have a carriage bolt brace design (orange part in animated image) I'm working on that can be reversed depending on your country. It should lock the thread down better as well as brace from the backside better for heavier items attached to the mount arm. Just a bit more testing but for now the main insert piece is fitting perfectly and securely. Gave it a few coats of textured paint to test before this goes off to be printed in PETG or better.
The files are available on my Thingiverse account if you'd like to have a go. Link to both LHD & RHD version is https://www.thingiverse.com/thing:7433328
awaken101
Postby DublinBlueElan » Wed 11.11.2026, 23:46
Love that you're doing something different! I'd love some door seal finishers for the top of the door card at the back.
1992 Aqua Blue se turbo
DublinBlueElan
Postby awaken101 » Sun 15.11.2026, 07:27
DublinBlueElan wrote:Love that you're doing something different! I'd love some door seal finishers for the top of the door card at the back.
Thanks! Are the door seal finishers those rounded corner caps, like quarter of a circle caps with the one screw hole in them? I ordered those awhile ago and I know I have one put on and will have to look for the other... but I can take the one off that I have and just reverse the STL file for it from the one. If you can confirm thats the piece you'd like I'd appreciate it. A photo would definitely confirm it if possible. Feel free to PM me or message me here. :cheers:
awaken101
Postby awaken101 » Sun 15.11.2026, 07:36
Someone had asked about the center arm rest insert, I was able to scan that but it didn't come out super awesome in CrealityScen. So with the help of Claude and my calipers we got it done.
I'm planning to tweak this original design a little. I'd like to have a hidden floor on this where I could perhaps put things like a key or small bills that would otherwise be taken from a open convertible. Just trying to figure out the best way to have it quickly accessible and have a fluid appearance that would not look obvious if you open the top of the arm rest. Stay tuned for that one.
I have not printed or fitted this one, I will be waiting to complete the hidden compartment design based on the original specs here before I send it off to print. If you would like just the original design (sans flocking) you can grab it here:
Link: https://www.thingiverse.com/thing:7435391
awaken101
Postby awaken101 » Thu 19.11.2026, 04:17
Newest 3D print: a clock replacement that wires in to its power and gives you USB-C & USB-A ports. Made some small tweaks from what you see here but the overall fitment is nice and snug for that hole. https://www.thingiverse.com/thing:7433680
awaken101
Postby DublinBlueElan » Thu 19.11.2026, 12:21
Love this
DublinBlueElan
Postby Tuga2112 » Thu 19.11.2026, 16:48
awaken101 wrote:Newest 3D print: a clock replacement that wires in to its power and gives you USB-C & USB-A ports. Made some small tweaks from what you see here but the overall fitment is nice and snug for that hole. https://www.thingiverse.com/thing:7433680
i would steer away from any usb charging that is not properly switched.
either with a phisical button. or by being plugged to a fused wire that is only powerred when ignition is on (i believe in the elan those are the green ones)
I Have had in the past a usb charger plugged to a fused constantly live wire (i believe purple) which was perfectly fine for a few months. there was no parasitic drain.... until the circuit got hot and somehow continued working... but had burn marks and was causing a parasitic drain.
i believe the issue was caused by the fact it was permanently switched on, even tho i was not charging any phones.
Postby DublinBlueElan » Mon 23.11.2026, 13:25
I was thinking about your 3D scanning and It got me thinking about tail lights.
We have had fibreglass tail light pods to accept circular lamps doing the rounds but what's stopping a 3D printed solution?
You could custom design a light fitting the same size as our tail lamps to accomodate circular light pods.
Something like the Elise lights to keep it lotus, McLaren F1 lights to add to the shared quirks and features, or other generic Hella supercar/back-of-a-bus lights from the 90s
If you had a scan of the back of the car without lights, you could create a base to build from, make your design and then confirm depths by overlaying a scan of the back of the car with lights.
OR......if you could find them....... you could 3D scan a set of already made pods and recreate as needed.
Personally, I'd love to see lamps mounted into vertical pods that do not angle down to the bumper, have them positioned a little closer to the outside of the car, and maybe the pod be 3D printed in a faux mesh pattern like the back of a 355 challenge stradale
I have no design experience or 3D printer just an idea.
I'm sure if you got this off the ground it would be a lucrative little side hustle with the Elan and Alpine GTA community
DublinBlueElan
