Elan expert required, please!
Postby dcj78 » Sat 15.09.2007, 16:31
I'm in the process of purchasing a 1990, G-reg, British Racing Green, Elan. I test drove it today and it needs a bit of work, but I'm not sure if it's turbo or non-turbo.
There was a boost gauge in the car and the car had discs all round (vented at front). This strikes me as a turbo. The log book didn't state turbo though.
I'm hoping to work on the car during the winter and have it ready for Le Mans next year.
Any assistance to start me off would be much appriciated. :)
dcj78
Postby dedmans » Sat 15.09.2007, 19:30
Hi,
If you lifted the bonnet you will see the unit on the front of the engine with turbo on it!
If it is there but not working properly you probably have a seized dumpvalve.
I have just posted with a cry for help in trying to get mine to work properly!
All black S2
dedmans
Thanks.
Postby dcj78 » Sat 15.09.2007, 19:41
Cheers.
dcj78
Postby Paul.P » Sat 15.09.2007, 19:48
dedmans wrote:If it is there but not working properly you probably have a seized dumpvalve.
Emmmmm, think you might mean seized wastegate, as the elan was not fitted with dumpvalve as standard ?
Postby dedmans » Sat 15.09.2007, 20:01
Sorry about that I get my words muddled up!
All black S2
dedmans
Postby Monty » Sat 15.09.2007, 20:22
dcj78
Is that the picture of the BRG u`ve test drove? as the inner wings look white to me or is that just the flash/sun :?
Postby John_W » Sat 15.09.2007, 20:47
Monty wrote:dcj78
Is that the picture of the BRG u've test drove? as the inner wings look white to me or is that just the flash/sun :?
The turbo is the thing under the heatshield with "turbo" written on it (red outline on pic). It doesn't look like a UK spec 1990 car, because it has an O2 sensor (green outline).
If it has a turbo boost gauge, it's an SE. The n/a version has a clock in that position (the SE has an oblong clock you probably won't have seen, because it's hidden by the steering wheel and the indicator stalk).
Brakes are the same for SE, S2 & n/a versions.
Postby lotuska » Sun 16.09.2007, 06:54
Can't believe that this is a picture of the car you drove, unless it's a LHD, note the brake master cylinder is behind the water header tank.
lotuska
Postby Doug » Sun 16.09.2007, 08:08
aren't you guys reading the thread title a bit too much
well, the red rubber cover on the boost gauge transducer says it's not an S2 model too :wink:
perhaps there is an LEC member local to you who can look the car over? Otherwise you can post all the info about the car and pictures and we can be as "helpful" as you want.
Postby stevo » Wed 19.09.2007, 18:36
you sad bunch of spotters. :roll:
the ac pipe on the left of the block means its prob a fed spec car. cough. 8)
stevo
Postby theelanman » Wed 19.09.2007, 21:37
lotuska wrote:Can't believe that this is a picture of the car you drove, unless it's a LHD, note the brake master cylinder is behind the water header tank.
:agree: :shock:
Postby Specky » Wed 19.09.2007, 21:45
:agree: :shock:
Who said it was... :shock:
He test drove a BRG, that'd white un.. :roll:
Postby theelanman » Wed 19.09.2007, 21:51
Specky wrote:
:agree: :shock:
that too is a good spot.....
its a pic of a fed car showing where the turbo is......
reading too much into it again....doh......cant see t'wood fert trees :shock:
Return to Elan Buying Help
