i,m trying to remove the chassis - i,ve got all the bolts out - by hook or crook - and the thing is still stuck to the shell - am I missing something ?
thanks again - that's the chassis dropped norman lovie wrote::bananasex: thanks again - that's the chassis dropped
to close out on the post
Simon_H wrote:The body went on originally with the engine in place so it should be possible.
AJSGSE1990 wrote:norman lovie wrote::bananasex: thanks again - that's the chassis dropped
Do you think it is possible to remove the body off the chassis with the engine still in place?
Thanks,
Andrew.
Tuga2112 wrote: Can't see why not, if you check the first 30 seconds of this video you will see none of the body around the engine https://youtu.be/HFnmgukX7Ak?si=-tYEp_LjoPG5uIfI
