by epipete » Tue 19.05.2015, 17:34
My mechanic advises that my pump is leaking, (there is certainly a lot of fluid around the vicinity which I thought was due to the bodged low pressure pipe that was in there). At present I don't know the nature of the leak, however is it possible to refurbish these pumps, seals, bearing etc.
Has anyone done this?
Pete
by epipete » Wed 20.05.2015, 10:05
Or, was this pump developed solely for the Elan, or is it freely available off another GM vehicle and if do then which ones?
Can any one look at their spare (out of car) pump and advise if any part nos or other marking on it, please?
by Brit-Car-Nut » Wed 20.05.2015, 17:26
Pete: There are rebuild kits listed on Rock Auto for the GM pump under the GEO Storm, 1991 both the SOHC and DOHC version use the same kit. It is only gaskets and seals.
GATES Part # 348415 $16.91
ACDELCO Part # 36348415 $19.41
by epipete » Wed 20.05.2015, 17:57
John, You really are my saviour. Thank you very much.
Return to Chassis & Steering
