Fed airbag disconnect
Postby peter canepa » Mon 11.12.2023, 05:10
I've decided to keep the original steering wheel, but have it re-wrapped in real leather by a local craftsman. Now how do I disconnect this orange plastic connector? After starring at it for an hour, and I do not want to damage it.
Damm this car looks good
peter canepa
Re: Fed airbag disconnect
Postby TorqueHorse » Mon 11.12.2023, 07:51
There is a FED SIR service notes document somewhere (can't remember if dapinky has it in the manuals section) and has illustrations showing those connectors. but in the meantime...
Make sure battery has been disconnected for a long time first, and do at your own risk.
The narrow side of that connector that is center of your photo: it's a little hinged locking tab that you pull up to release, and then you can pull the connector apart.
'91 FED M100 -rolling resto
Postby peter canepa » Mon 11.12.2023, 18:08
I did disconnect the battery, The long time part? Its been overnight. I can see on the narrow side, what looks like a round bar with a hinge looking tabs on each end.
Yes I'm being careful. Thanks for the support
peter canepa
Postby TorqueHorse » Tue 12.12.2023, 00:09
Here, easier than me trying to describe :)
Postby peter canepa » Wed 10.01.2024, 02:19
Thanks, TorqueHorse, That helps a lot, :clap:
Peter Canepa
peter canepa
Postby Giniw » Wed 10.01.2024, 02:25
TorqueHorse wrote:There is a FED SIR service notes document somewhere (can't remember if dapinky has it in the manuals section) and has illustrations showing those connectors. but in the meantime...
Please see Brit-Car-Nut manuals page: http://www.lotusm100.com/manuals/ (I don't think dapinky's page has it listed)
Yes you need to remove the fuses/connectors & all.
Not difficult, you just need to follow the procedure and handle the airbag properly (not towards your head for instance). But the risk of it inflating for no reason is not really greater than when you drive in front of it anyway, right?
Giniw
Postby peter canepa » Thu 18.01.2024, 20:42
Thanks for the link to the Brit-Car-Nut manuals! Big help!
peter canepa
Return to Chassis & Steering
