by philip_sloper » Wed 21.12.2005, 19:40
I finally managed to reduce the file size of my picture to below the 10K maximum to allow it to be uploaded into my profile, but the image quality is cr*p whereas the original was pin sharp.
I notice other people have good quality profile pictures, what's the secret?
philip_sloper
by F1 LOTUS » Wed 21.12.2005, 20:58
How did you reduce it?
F1 LOTUS
by philip_sloper » Wed 21.12.2005, 22:01
Re-sized to 150 pixels wide in Photoshop, then saved in lowest file quality.
philip_sloper
by surfboardfiller » Thu 22.12.2005, 15:28
philip_sloper wrote:I notice other people have good quality profile pictures, what's the secret?
I saved the resized image as JPEG at high quality from photoshop then opened up in MS Paint and saved. Did the trick for me (much to my amazement)!
Photoshop doesn't compress very well for some reason!?
If you have a mac: I don't know.
surfboardfiller
by Doc Fizzix » Thu 22.12.2005, 16:40
philip_sloper wrote:Re-sized to 150 pixels wide in Photoshop, then saved in lowest file quality.
Do the following:
- Select "save for web"
- then in the next window make sure you select that you want to save as a jpeg.
- the addjust the quality slider until the image is 60%
- then select save image
- then you are done
Doc Fizzix
by surfboardfiller » Thu 22.12.2005, 17:41
LotusM100 wrote:Do the following:
- then you are done
Save for web; good call!
surfboardfiller
by philip_sloper » Thu 22.12.2005, 19:26
OK, that worked.
Many thanks.
philip_sloper
by philip_sloper » Fri 23.12.2005, 17:26
Brian_MDB wrote:Oh! So it really IS pink
No it definitely isn't! It's as red as my eyes will be on 1/1/06!
philip_sloper
