for sale 1990 blue elan se turbo (SOLD ON GUMTREE?)
Postby munch power » Thu 26.09.2013, 15:24
my elan is for sale as there is no spark
munch power
Re: for sale 1990 blue elan se turbo((((((only 58000 on cloc
Postby Ladythorpe2 » Thu 26.09.2013, 16:03
You have PM.
GW
Ladythorpe2
Postby clemo » Thu 26.09.2013, 19:46
munch power wrote:my elan is for sale as there is no spark
As in you don't love it anymore or it missfires?
clemo
Postby Ladythorpe2 » Fri 27.09.2013, 09:46
Hi
Are you still looking to sell?
please contact me if you are.
GW
Ladythorpe2
Postby muley » Fri 27.09.2013, 22:35
Munch
You have PM..
..Jim
Postby munch power » Tue 01.10.2013, 17:01
yeah car is up for sale ,fault code 12 flashing on dash just had new coil packs ,but still no spark
munch power
Postby muley » Tue 01.10.2013, 17:04
Price?
Postby munch power » Tue 01.10.2013, 17:18
not sure ov a price lol pm me your offer m8
munch power
Postby theelanman » Tue 01.10.2013, 18:13
munch power wrote:yeah car is up for sale ,fault code 12 flashing on dash just had new coil packs ,but still no spark
Code 12 is all ok......
Postby theelanman » Tue 01.10.2013, 18:15
Code Fault
12 None
13 O2 sensor (or circuit) malfunction -- see CommonParts replacement
14 High Coolant Temperature (relative to other measurements)
15 Low Coolant Temperature (relative to other measurements) -- see CTS write-up
21 Throttle Position Sensor (Signal Voltage High)
22 Throttle Position Sensor (Signal Voltage Low)
23 Manifold Air Temperature Low (relative)
24 Vehicle Speed Sensor
25 Manifold Air Temperature High (relative)
31 Manifold Absolute Pressure (Turbo Overboost)
33 Manifold Absolute Pressure Sensor (High voltage / Low vacuum)
34 Manifold Absolute Pressure Sensor (Low voltage / High vacuum)
35 IAC error IAC motor not controlling the engine to the desired speed
41 Cam Angle Sensor (Hall Effect Sensor) -- see CAS write-up
42 Electronic Spark Timing circuit
43 Electronic Spark Control (Knock Sensor Circuit)
44 Lean exhaust
45 Rich exhaust
51 ECU Fault ($$$OUCH$$$--get a new ECU)
53 Over voltage (system voltage high)
54 CO-Potentiometer circuit
65 Fuel injector driver circuit (or output) problem
Postby Enright » Tue 01.10.2013, 21:01
I'm confused. The pics of the car are all in the problem solving thread, yet the problem solving is now in this one, and another one has just been started (which I've nuked).
In the same way that pressing a lift button doesn't make it go any faster, scatterbombing the forum WILL NOT get the problem sorted any quicker - it will just annoy normally helpful people as they'll have to read the same stuff in lots of different places.
Postby rip » Wed 02.10.2013, 17:05
Enright wrote:I'm confused. The pics of the car are all in the problem solving thread, yet the problem solving is now in this one, and another one has just been started (which I've nuked).
What's this, duplicate threads being deleted?
The old Enright is back :smt023
Postby Enright » Wed 02.10.2013, 18:11
...and it looks like I've got a bit of catching up to do, Mister-I've-nearly-got-5000-posts!
I'd better either get posting lots, or get devious and delete a few surplus ones of yours matey!!! :poke: :twisted: :bananasex:
Postby lotusgirlmarie » Wed 02.10.2013, 18:27
Sorry to hear your selling it on because of the issue. Solved ekapol's no spark issue by fixing the grounding issue to the head (the mechanic forgot to attach the lead to the grounding lug on the back of the head near the power steering reservoir). My spark issue was a faulty ground to the coil base plate. It's a shame that something so minor had soured your experience.
lotusgirlmarie
Goddess
Postby munch power » Thu 03.10.2013, 14:16
has lots of history also has full log book ,brakes are sticking on due to being stood ,think it has full stainless exshaust system not sure will have a look ,all parts
munch power
Postby munch power » Wed 16.10.2013, 10:29
been a bit busy at the moment but the elan still has a spark issue ,this morning seen that the laquer is peeling and bubbiling up as the weather is getting to it now,it has every mot from new and every bill for everything ever bought and replaced on the car ,has all history up untill it stoped working 5 year ago
munch power
Postby clemo » Fri 18.10.2013, 22:40
hi there ,
do you think this car could go back on the road ?
has it been standing outside for 5 years?
clemo
Postby munch power » Fri 18.10.2013, 22:54
its been in a garage until the begining of this year its now on a driveway at the moment ,wen pulled out of the garage it was in the carpets were dry but a bit green but ,the car us coverd up at the min as its starting to get wet has two holes in the roof but cud be fixed ,everything has been checked and everything points to the ecu not working the brakes were stuck on but have been free'd ,ladythorpe2 has come and viewed the car, with a bit ov time spent on her she would be on the road in no time ,last tax'ed in 21/6/2008 ,will take photo's tomorrow so you no what the elan looks like inside and out for you clemo
munch power
Postby munch power » Thu 07.11.2013, 13:30
still for sale
munch power
Postby clemo » Fri 08.11.2013, 22:24
did you do the interior photos?
clemo
Return to SOLD Cars
Users browsing this forum: No registered users and 197 guests
