Lotus project NOT for sale (KEEPING)
Postby norman lovie » Sun 16.06.2019, 11:46
Elan reg. M33 3LAN mark 2 project for sale
long story some of which is on this forum from a good few yrs back
brief summary is I removed the chassis to repair minor corrosion issues - spend a lot of time taking all the chassis and suspension parts back to metal - a few minor patches to the chassis - then full phosphate / twin pack epoxy coating and waxing - got as far as refitting the front suspension with new dampers bushes wheel hub bearings etc..
The outriggers in the tub were as best as possible de rusted and treated / painted /waxed - and this is where I left off
I've bought a load of good stuff for the project as advised / sold via this forum- SS gearshift cables / front anti roll bar mounting kit / brake servo M/C upgrade etc..
I also bought pritty much a complete engine overhaul kit - cam belt bearing pulley kit - gaskets - shell bearings etc..
A new radiator, and samco hose kit
TBH without going back through all the boxes I don't recall everything acquired and stashed away
There is x 2 engines c/w cast ex manifolds - both were good runners - one of the manifolds is free of any cracks
There is a chip with the ECU ( it had a broken connector leg which I found on removing and may have been the root cause of an intermittent fault which caused the car to drop into fail-safe mod. - don't know for sure
Ok - sorry this is not a detailed list sufficient for anyone to make a decision but i'm hoping its enough to gain some interest such that someone would like to come over and see for themselves - I can say that this was a good running car that I took apart ref: previous mentioned chassis / suspension corrosion that ive put right and is ready for re assembly, or a starting point for someone to continue with more restoration - the tub is in reasonable shape ref: paintwork - could do with a re spray, could also do fine as is
I would make more parting it out but don't want to - its too good a basis not to rebuild
i'm at AB54 4TE Huntly area - 07717346357
here's hoping someone local is keen for a project and can put this car back where it belongs
thanks
norman lovie
Re: Lotus project for sale
Postby Rambo » Sun 16.06.2019, 16:50
Sounds like a good winter project for JohnW. Once he sorts out his injector problems :poke:
Postby norman lovie » Tue 18.06.2019, 09:50
In the middle of a big clear out do yo house move - coming across stuff stashed away so i'll add as I find
two turbo's in good nick
injectors have been cleaned and calibrated - like new
new set of ferrado race pads ( discs and brakes were new when I got the car ) the rear brake bias valve was rebuilt when I started re assembling
2 speedo clock clusters ? don't recall why I bought a spare
new thermostate and a plastic divertor thing - thinks its for the heater
new fuel regulator and a roll of small bore vacuum hoses - blue ( same as the samco coolant hose kit ) so blue it is - car is blue :)
new front ball joints and wheel bearings fitted - also have a spare new front ball joint
full engine gasket set - new water pump and belts
2.5" SS rear box ( rest of ex system is std and good )
little packets of things like the red plastic door trim bits - a kit for fitting the front wheel arches etc..
some new engine sensors - looks like a thermo switch sensor and I think a speedo sensor ( fits in the back of the speedo cluster )
new smaller bore brake M/c
new front shocks + originals ( rears are originals ) originals are in typical rusty state - worked fine - my plan was to fit new rear shocks but didn't get to this
norman lovie
Postby norman lovie » Fri 28.06.2019, 09:35
well I put a couple of days chav into the car - amazingly found all the right bits n bobs n bolts and got the car on 4 wheels with an engine and the tub sitting back onto the chassis - all temporary for moving but good to know my "filing system" from about 6yrs ago seems to have worked - also rekindled my interest in finishing this project - basically i've done a lot of the crap corrosion hault and prevention work and a bunch more - got a s**t load of spares already procured - soo the cars moving with us :bananasex:
norman lovie
Postby cliff » Fri 28.06.2019, 12:28
norman lovie wrote:well I put a couple of days chav into the car - amazingly found all the right bits n bobs n bolts and got the car on 4 wheels with an engine and the tub sitting back onto the chassis - all temporary for moving but good to know my "filing system" from about 6yrs ago seems to have worked - also rekindled my interest in finishing this project - basically i've done a lot of the crap corrosion hault and prevention work and a bunch more - got a s**t load of spares already procured - soo the cars moving with us :bananasex:
That's good news.
I think this happens to all of us, I know when I came to put mine back together, there were some serious moments of OMG (or words to that effect) what have I done! We are all rooting for you and ready to offer advice when needed. Go for it, it will be worth it in the end.
91 Lotus Elan SE Turbo
07 Alfa Spider 939
cliff
Re: Lotus project (not) for sale (anymore)
Postby John_W » Fri 28.06.2019, 19:35
:smt023
Where are you moving to?
Postby lotusles » Fri 28.06.2019, 20:36
John_W wrote::smt023
Hopefully near to me, as somebody that enthusiastic can only be a bonus :D
lotusles
Postby norman lovie » Sat 29.06.2019, 08:38
not far - outskirts of Dufftown - will be a while before I get settled and sorted then i'll rekindle a project page - and indeed will be most thankfull for the detail assistance
Learned a lesson yesterday "do not move an Elan without fitting the drive shafts - or an equivalent bolt n washers - - the front wheels may desire to part company with the bearing hub :bonk:
norman lovie
Return to SOLD Cars
