New ECU add-on boards available - Form an orderly queue!
Re: New ECU add-on boards available - Form an orderly queue!
Postby philipdart » Mon 08.04.2024, 18:29
WombleJnr wrote:1 - 17. Delivered
18. Whiteelanman - Delivered
19. yoboy (Stu) - Delivered
20. By Email - Delivered
21. BarryDalHerbert - Delivered
22. Jon - Delivered
23. MikeM - Delivered
24. Elanthrapist - Delivered
25. viruses61 Via PM - Delivered
26. Chriswin - 1499 Everest X2? - In progress
27. Chriswin?
28. Karlos
29 . WombleJnr - checking PROM, Everest.
30. philipdart standard, dual image 9930/1499 please (currently on open loop with existing 9239 Eprom Feb 1992 SE)
1992 Elan SE
1997 Esprit GT3
philipdart
Postby RonR » Tue 09.04.2024, 13:18
Small update time again....
1 - 27. Delivered
28. Karlos - Decision pending....
29. WombleJnr - On it's way to NZ
30. philipdart - standard, dual image 9930/1499 please (currently on open loop with existing 9239 Eprom Feb 1992 SE)
NOTE: I've recently had problems reported with 2 installations. One looks to be related to a Closed Loop conversion - Long-distance diagnosis is always tricky, but it looks like the alternator isn't putting out enough current to run the O2 sensor heater, so it's probably fitted with the wrong Voltage Regulator. The other's a mystery for now, I'll know more in a few days.
Meanwhile a new batch of boards is being fabricated and the multiple-prom switcher is nearing completion.
Postby Tuga2112 » Tue 09.04.2024, 16:16
RonR wrote:NOTE: I've recently had problems reported with 2 installations. One looks to be related to a Closed Loop conversion - Long-distance diagnosis is always tricky, but it looks like the alternator isn't putting out enough current to run the O2 sensor heater, so it's probably fitted with the wrong Voltage Regulator.
Ron.
I Can confirm that a brand new alternator from SJS will NOT operate correctly with a closed loop conversion.
When i converted to closed loop. the alternator charge light came on. I had to swap the alternator (for the 6th time in a year) with the one i refurbished using SimonP's kit, in order to get things running.
hopefully SimonP will be willing to disclose the exact regulator was included in he's kit, as id like to swap the regulator from the sj alternator with a close loop compatible one so that my spare is ready for close loop.
Postby Fredjohn » Tue 09.04.2024, 22:09
Just to add, I converted to closed loop and have also installed Simon's alternator repair. It all works fine.
Postby RonR » Wed 10.04.2024, 18:45
AFAIK the original voltage regulator had Denso part number: 126000-0440, it has the "C" terminal and produces enough current from the "L" terminal to run the O2 sensor heater.
Postby RonR » Mon 15.04.2024, 19:36
Last week I found the second installation problem, which was due to a faulty IC socket. The board tested OK when it was built, but the chip was making intermittent contact with the socket when in the car. Think I'll start to include a "Put it in a box and shake it about" test for future boards!
BTW I've replaced the duff board and all is now well.
Postby RonR » Wed 17.04.2024, 16:03
1 - 27. Delivered
xx. Karlos - Sold the car!
28. WombleJnr - Delivered
29. philipdart - Posted
30. kevrob - TBD
Postby philipdart » Wed 24.04.2024, 18:11
Huge shout out to RonR for sorting the new chip set-up for me. I've gone closed loop on my Feb 1992 SE (wires were there), kept it standard rather than uprating the bhp and I''m absolutely delighted. It's pulling so much better than it was and cracking open the ECU and adding the board was really straightforward. 30 inch breaker bar needed to removed the bung to be able to fit the O2 sensor was the worst part - worried that I'd crack something after 32 years of it being there, but all good! Thanks so much Ron!
RonR wrote:Small update time again....
1 - 27. Delivered
30. kevrob - TBD
1992 Elan SE
1997 Esprit GT3
philipdart
Postby Geordie » Thu 25.04.2024, 12:31
Hi ya
I’ve also fitted one of RronR chips (Everest) and changed to close loop,that bung for the 02 censor is a challenge ,bit of heat ,large bar and fingers crossed did it for me ,car responsive and getting roughly 36 MPG return ,,,,,,couldn’t be happier
Geordie
Geordie
Postby RonR » Wed 01.05.2024, 13:05
My first 3D-Design and print - The prototype switch housing for the upcoming multiple-prom boards:
For now it's only a low-grade plastic, the real items will better match the other switches.
Please excuse the dust, the car's been off the road for a while, also the display is much brighter than my phone camera makes it out to be.
Postby Tuga2112 » Wed 01.05.2024, 13:07
id be fitting that in the balnks next to the digital clock
Postby dapinky » Wed 01.05.2024, 13:46
Looks good, Ron.
I've got mine where your hazard switch is, the hazard switch where your fog light is, and the fog light where the switcher is - I decided that as it nearly blends in, but not quite, it would be better centralised in the 3 locations.....
Postby Fredjohn » Sat 04.05.2024, 18:26
Ron....I've sent you a PM. Fredjohn
Postby sinannasirli » Fri 31.05.2024, 21:34
Hi.. can i please order one?
1996 Lotus Elan Turbo S2, Empire Green, No 766
1995 Maserati Ghibli 2.0
2000 Porsche 996 Carrera 4
1969 Chevy K10 Suburban 4x4 i6 250ci
1970 Opel GT
1953 Willys CJ-3B Jeep
1958 BMW R26 Motorcycle
sinannasirli
Postby Swerveking » Mon 24.06.2024, 20:36
Hello, I'm a new member here and wanting a chip upgrade for my 92 federal Elan. From what I've read, the 1499 closed loop Everest is the best choice for me here in Texas. I'm not sure about multiple eproms or maps are something I should consider. Please advise on current status and if these are still available. Thanks, Allan Rumsey
Swerveking
Postby Swerveking » Tue 25.06.2024, 00:28
Prev replied but don't see it went through. I need a chip! 92 federal car in Texas. Let me know if they are still available please.
Swerveking
Postby RonR » Wed 26.06.2024, 10:57
PM on it's way.....
Postby carpecaseus » Sun 07.07.2024, 16:58
Hi RonR,
Just dropped you a PM about getting hold of one. Thanks in advance.
Laurie
carpecaseus
Postby RonR » Mon 08.07.2024, 12:55
PM coming your way Laurie!
Postby Blue ass fly » Mon 08.07.2024, 18:31
Hi ronr
Interested in converting my SE to closed loop with everest
I think its 1499 i need
Please pm to arrange order
Thenks
Steve
Blue ass fly
