RonR wrote:Small update time again....
1 - 27. Delivered
xx. Karlos - Sold the car!
28. WombleJnr - Delivered
29. philipdart - Posted
30. kevrob - TBD
PWillcocks wrote:32. PWillcocks - 1994 S2, 1499 Everest please
Squirtydog wrote:One thing I noticed at first was that it took quite a firm push of the accelerator into the floor to get the full boost. Checked the throttle cable and found there was around 8mm of stretch to be taken up. Adjusted and problem solved. Not sure how long I've been driving without full throttle available.
dapinky wrote:There is usually (what looks like) quite a lot of slack in the cable when it is correctly adjusted...... the best way is to use Elanscan and watch the throttle opening percentage (not with the engine running, otherwise it can get a bit loud!). If full pedal doesn't give 100% throttle, then it needs adjusting - then it is a case of deciding if it is the TPS or the cable that needs the adjustment.....
With the help of a (not always) willing assistant, press the pedal, look at he laptop screen to see what %age opening you have, then have the assistant operate the lever under the bonnet to check it goes further than it's current position, and gives 100% on the screen - if so, adjust the cable to give 100% with the pedal only.....
.... if there is no more movement available at the lever, then it is a different set of things to play with at the throttle body (but that is less usual).
It is a great time to check the TPS position, idle speed etc whilst you are in there.
MPx wrote:Something along the lines of a sin wave form output is taken from something(maybe Cam Angle Sensor??)
Jube wrote:Hi Ron, just to let you know that I've sent you a PM regarding the Add-On Boards and Chips. Thanks.
