New Arias Forged Pistons
Postby Keefover » Sun 03.08.2014, 20:37
Hello all,
I am Jordan Keefover, Isuzu enthusiast and owner of Overspeed Motorsports. I was in recent need of some forged pistons for the 1.6l 4xe1 turbocharged power plant in the 1991 Isuzu Impulse RS. I contacted a well known US piston manufacture by the name of Arias pistons and arranged for a small production run to be accomplished. Most of the sets are spoken for but I figured I would give you guys a crack at them as well. This is the link in the Isuzu website where they are for sale. http://www.isuzone.org/forums/showthread.php?t=26390
If you are interested please feel free to contact me via private message or by email at Overspeedmotorsports@gmail.com
Details:
80.5mm bore
9.2:1 CR
Double pin oilers
Floating pin design
Retention of stock wrist pin specs (20mm by 2.5in)
All pistons come with rings and retainers. If you want pins it's a separate charge.
Price USD $519.00 with out pins, $569.00 with pins.
Shipping is not included in the price but you can chose the method of preferred shipping you would like me to use.
Keefover
Re: New Arias Forged Pistons
Postby dapinky » Sun 03.08.2014, 21:15
Hi Jordan,
message posted on Isuzone thread to keep it in one place for you :D
Postby dapinky » Tue 05.08.2014, 00:45
Right, I'm in for a set of these (all sorted on the other forum!)....
.... now, I'm the only (current) UK buyer, but was wondering if anyone else is thinking of a set and would want to combine postage - I've already offered to play postman to Jordan (the organiser) if anyone else is getting on board.
Postby nicowalker1 » Tue 05.08.2014, 21:19
dapinky wrote:Right, I'm in for a set of these (all sorted on the other forum!)....
Hey Dave, what would be the benifit of these?
nicowalker1
Postby dapinky » Tue 05.08.2014, 22:12
Nick, for you, probably no benefit......
..... I want them for my old engine, to do a full re-build on it.
One of the reasons I swapped it out of the red elan (apart from the HG having gone) was that when I had the head off, the pistons seemed a bit loose in the bores, and as it had 150K on the clock, will benefit from a re-bore and new bearings for the crank.....
...crank bearings are cheap and readily availlable, but pistons (being forged on the Turbo, as opposed to cast on the NA) are a custom made item (Lotus went obsolite many years ago, as did Isuzu).
Getting them in the UK is ridiculously expensive (SW Lotus list them at nearly £700 - and they get them from Robie The Robot in USA) - they are $630 + postage from him, so these ones will save me a few quid.
Standard pistons are 80mm diameter, so these are 0.5mm oversize, to allow for a 0.020" overbore (I know we shouldn't mix metric and imperial measurements, but they are listed in metric and I still think in imperial).
If you don't need a re-build, then theyre no great use to you!
(except it will increase your engine size by a few cc's - more :burnout: )
Postby abmunro » Wed 06.08.2014, 09:51
These pistons should allow the boost to be turned up and therefore more power!!!
I was thinking about installing these in my spare engine, the one that has only done 8 miles .
abmunro
Postby dapinky » Wed 06.08.2014, 10:41
Tony,
would it not make more sence to fit the spare engine in the car, then re-build the one you are currently using????
Postby Keefover » Mon 15.09.2014, 08:08
Gents,
One more set has become available. You have to love it when someone commits and backs out of the sale. Please let me know if anyone is interested. Dave bought a set from me and shipped they were right about 400 pounds total. Your exchange rate favors you big time.
Thanks in advance,
Jordan
Keefover
Postby Rambo » Mon 15.09.2014, 09:53
dapinky wrote:Tony,
Yes ;-)
Postby abmunro » Mon 15.09.2014, 15:00
Currently there is nothing wrong with engine in the car.
Its only done 25000 miles
The spare engine is exactly that a spare. It has only done 8 miles.
I hadnt read Daves message above properly, I didn't realise we already had Forged Pistons.
Tony
abmunro
