Water pump "best place to buy"
Postby Tannerman » Sun 17.04.2016, 13:34
Hi all firstly apologies for not being on here or posting for a while but been mad busy with things.
Started the Elan this morning for the first time in about 6 months started first turn all good...
Took her for a run around the block and noticed the temperature above half ( which it never is)
Anyway long story short it looks as though the water pump. Has gone literally peeing out so I need a new one and I'll do belts while I'm at it.
Question where is the best place to buy seen lots of mentions of rock auto etc but nothing decisive
Thanks guys need to get her in rude health and get on some meets again :-D
Lotus Elan M100 1990 (red
VW Tiguan R Line
Ford Transit Jumbo
Toyota Celica 25 th anniversary model
Tannerman
Re: Water pump "best place to buy"
Postby HJ2 » Sun 17.04.2016, 16:40
I'd indeed say Rockauto.
How is the condition of your thermostat?
Postby Rambo » Sun 17.04.2016, 17:37
RockAuto
I've ordered about 6 sets from them over the years for my cars and other LEC'rs. Excellent service every time
Postby Fredjohn » Sun 17.04.2016, 18:15
I'd agree...Rock auto every time.
Just be careful when ordering that items come from the same location, otherwise you get stung for multiple shipping charges. Also make sure the pump and belt have the same rounded profile.
Whilst you are in there don't forget to change the cam belt tensioner and adjuster as well as the intended water pump and cam belt.
Postby Rambo » Sun 17.04.2016, 18:28
You may as well get the belts too - PAS, alternator etc... :twisted:
Postby Tannerman » Mon 18.04.2016, 14:54
Cheers guys is it the impulse one I need to order for :D
VW Tiguan R Line
Ford Transit Jumbo
Tannerman
Postby Brit-Car-Nut » Tue 19.04.2016, 00:15
Yes, but make sure it has the rounded profile type drive pulley. There were some square profile pumps that got mixed into the parts bin and sending one back to the US is not cheap and it wastes a lot of time.
From R/A:
AIRTEX AW9220 {#WP717} Includes Gasket: This pump is driven off the timing belt. Timing belt should be replaced with the pump.; This pump is supplied with a round-tooth pulley. This pump is not interchangeable with the AW9221. Failure to use the correct pump could result in severe engine damage.
This is the only pump I have seen that consistently has the correct pulley
Postby ovi » Fri 22.04.2016, 13:51
I used the previous set of rockauto for my yellow Elan and some years later ordered a complete set which I have recently seen that they have supplied the wrong pump! :evil:
Return is indeed too expensive.
ovi
Postby tb10 » Fri 22.04.2016, 14:48
ovi wrote:I used the previous set of rockauto for my yellow Elan and some years later ordered a complete set which I have recently seen that they have supplied the wrong pump! :evil:
That happened to me as well, the wrong pump was supplied. I did buy two extra in any event but I have used those and still have the 'wrong one'. Not too fussed given the price but even so.....................!
tb10
Postby Brit-Car-Nut » Fri 22.04.2016, 16:48
Having ordered and forwarded several water pumps for UK owners, I know that the AIRTEX AW9220 pump IS the correct profile. The Bosch one that used to be available is also correct but it was discontinued.
Postby tb10 » Fri 22.04.2016, 17:44
Hi John,
The one I received was in the right box but totally the wrong pump!! I'll dig it out and upload a photo. However, the tooth profile on the others was correct.
regards
PS John, could you please PM me the 'key in boot' solution? :-D
tb10
Postby Brit-Car-Nut » Fri 22.04.2016, 18:49
I guess being sure the right pump is put in the box is always a worry.
I know Rock Auto allows returns and I expect someone returned a different (cheaper but wrong) pump in the more expensive package. I sometimes get a package that has the wrong part inside. Being in the US, They usually just send me a replacement without asking for a return. The replacement always had the "right" part in it.
I will email you the PDF
Postby Rambo » Sun 24.04.2016, 18:03
Last order I put in to RA was for 3 Airtex water pumps. All arrived quickly in the right boxes with the correct pumps, round tooth profile on pulleys etc.........
Return to Heating and Cooling
