by rip » Wed 19.03.2008, 10:31
I don't know where the valve should be. I have simply been told that mine was missing, so I would like to put that right.
If somebody would show me at Donington, I would be grateful.
by dapinky » Wed 19.03.2008, 11:08
Ian,
Not the best picture, but it is the best i can find in the manual!
- LEC Administrator
by chris.t » Wed 19.03.2008, 13:09
it is located towards the rear bulkhead, top of the engine, RHS as you look at the front of the car. Pipework is approx 15mm dia o/s
by rip » Wed 19.03.2008, 14:53
Apart from one small hose which was well tucked away, I fitted the whole Samco kit myself.
I think I need another look.
by chris.t » Wed 19.03.2008, 15:20
rip wrote:Apart from one small hose which was well tucked away, I fitted the whole Samco kit myself.
effectively if your valve is not fitted your heater would be on all the time! unless it was looped out of course.
by mikeydude » Thu 20.03.2008, 17:05
Well, the valve really just stops water going through the radiator when the heater is turned down to nothing, I think it's to shop heat just trickling through in the summer etc. by actually turning off the radiator water flow.
As a matter of interest, my heater has never worked properly, It's almosr completely blocked up, in fact it was completely blocked until I blew with all my might through the hoses until it "popped" and a load of crap came out of it... I have used the radiator flush stuf a few times since. but to no avail.
I think alot of this must be caused by people not flushing out the system during the cars life!
I might try this idea of swopping the hoses so the water goes the other way for a while.
I often wonder if it should be left upto the smallest openings to collect deposits....the best idea would be surely to fit an inline water filter!! I wonder if there is such a thing!
mikeydude
Return to Heating and Cooling
