by Andy_J » Sun 11.05.2008, 18:51
I am sure this has been discussed before, but I can't find it via the search options.
Whislt I was parked up last night during a heavey rain shower I notied water dripping into the passenger foot well form behind the glove box.
On further inspection the water seemed to be comming out of the bottom of the casing surronding the heater fan.
Does not seem to drip when the car is moving. Cant see any cracks or gaps round the intake bit in the engine bau either
Anyone got any ideas?
Andy
90H BRG SE 48,000 Miles
Andy_J
by muley » Sun 11.05.2008, 20:04
Hmmmm. Leaking heater matrix?
Not had it happen on an Elan, though.
by Sy V » Mon 12.05.2008, 07:59
Yes, I think it's indicative of a perished vent pipe.
It used to come up regularly but I haven't seen the symptoms reported for a long time and I'm trying to wrack my brains as to the diagnosis.
Is there a pipe there that's made of or lined with foam? - I think that's the one to check first. But please wait for someone else to confirm before going on my word.
- LEC Godfather
by DeeAitch » Mon 12.05.2008, 09:09
If you take off the arch liner you will find a duct running from the front intake (May be part of the top shell?) which is joined with a foam seal - sort of wrapped around and held on with tie wraps?
I think this imay be the one Sy is thinking of? A few folk reported leaks from this area but haven't heard of any for a long time.
Mine crumbled away just by looking at it - replaced with a wrap of old inner tube
DeeAitch
by Andy_J » Mon 12.05.2008, 13:22
Thnaks Guys.
Did think about the bit behind the wheel arch liner, but could not work out how this bit would leak when the car was static.
I guess the cars are know for their ability to take in water from strange places. I will pull the liner off later this week when I have a free evening and have a look
Andy
Andy_J
by petsin » Mon 12.05.2008, 19:09
Hi Andy
I had the same thing happen to me last winter and when i took the liner off the foam sleave was soaked and had come off at one end. I replaced with a large inner tube and cable ties. Not sure if Lotus still do the foam, but its obviously a known problem as i'm sure its mentioned in the workshop manual under waterproofing. But hey with weather like this who needs to worry!
petsin
by lotuska » Mon 12.05.2008, 21:07
check the following
post it has a picture of the foam pipe.
The problem is that its located directly below the windscreen drain hole so any rain will drip onto it and if its got a hole will leak into the car.
lotuska
Return to Heating and Cooling
