Radiator bleed plug bolt thingy!!
Postby blacknight » Sat 07.06.2008, 13:30
Ok. Here goes...
Replaced head gasket....
Replaced water pump...
Replaced belts tensioners etc......
Only for bleed plug thing to snap off in radiator :evil:
Managed to get it out with minimal effort :D
Any suggesetions on how to replace/alternatives/spare one lurking in cupboard somewhere?
Please someone help me
Iain
Winter is the new summer...............best buy a hat!
blacknight
Location: Working on an Elan is like a box of chocolates........every one is a coffee cream!
Postby muley » Sat 07.06.2008, 13:57
Iain
I feel for you. It's a standard metric thread - I think this was reported by dapinky (?) - I'll have a look - so you could use a metal set screw(bolt) for the time being - don't tighten it too tight though :(
p.s. Yup - I had a check and here's the link
http://lotuselancentral.com/forum/viewt ... drain+plug
HTH
Postby dapinky » Sat 07.06.2008, 14:03
I did that as well :roll:
I used an M12 setscrew with a suitable washer/'O' ring - it was intended to be temporary but as i ended up with new end-tanks anyway, soon got dumped.
There are 3 different thread pitches for M12 - make sure you use the correct one for your endtank - the wrong one will force itself in and ruin the thread in the plastic.
Postby blacknight » Sat 07.06.2008, 14:55
Thanks guys :-D
I will pop down to the mighty fine establishment known as "nuts and bolts" when they open monday morning!
Ho Hum! When I sort this only CV boots and rear top suspension arms to replace.........Bugger!
Iain
blacknight
radiat0r bleed plug
Postby Ade » Sat 07.06.2008, 21:30
Hi
I used a bolt as suggested intending it to be tempary. It is still there after five years and no problems.
Ade.
Ade
Return to Heating and Cooling
