Heater (no blowing out hot air)
Postby localad » Fri 06.03.2009, 10:10
Hello boys and girls, wondered if anyone could help, my heater doesn't blow out hot air, only when I am giving it a bit of welly or on the motorway that ids does give some heat??? Any ideas what could have broken?
Many Thanks
Andy
localad
Re: Heater (no blowing out hot air)
Postby HJ2 » Fri 06.03.2009, 10:49
Is your heatervalve OK?
(see various treads about it, here on the fantastic LEC ) 8)
Postby Monty » Fri 06.03.2009, 11:50
Whats your temp guage showing on a normal run? sounds like the thermostat could be stuck open :?
Make sure the vacuum hose is still attached to the Heater valve.
Postby gmacz » Fri 06.03.2009, 18:08
Since you are getting heat when you are really working the engine, it tends to be a thermostat that is either stuck open or completely missing.
Do you have one of the quicker Elans --RED.
Yours Gmacz
The NaeLan Gives You Nae Trouble.
gmacz
Postby L.G. » Fri 06.03.2009, 22:49
One more vote for the thermostat. Easiest to check and the most likely problem. A less likely scenario is a rusted coolant making the heater unable to work which I had a couple of years ago. Actually the water pump was also shot so it could have caused the problem as well.
L.G.
'95 S2 driver #286
L.G.
Postby MattDon » Sun 08.03.2009, 14:28
i spent over a year with a similar problem, it turned out to be a vacumn hose that had come off, took 10 mins to find and sort out.
please use email for contact
MattDon
Postby localad » Mon 09.03.2009, 12:00
Wicked, is the pipe at the back if the engine, had a look but couldn't see much !!!
localad
Postby bobbrown » Mon 09.03.2009, 14:50
localad wrote:Wicked, is the pipe at the back if the engine, had a look but couldn't see much !!!
this may help
Pacific Blue N/A
Postby localad » Mon 09.03.2009, 18:47
Hi Bob this is awesome, will check it out !!!!
localad
Postby bobbrown » Mon 09.03.2009, 19:33
It is of course all available in the service manual and can be downloaded from the site.
http://www.lotuselancentral.com/manuals.htm
Pacific Blue N/A
Postby Doug » Mon 09.03.2009, 20:49
I will vote against the t-stat. Reason is I had one that would stick open and the dash temp gauge would read low, but my heater function was still acceptable.
My candidates = vacuum hose to heater valve; heater valve itself; bad linkage to air mixture flap; bad blower motor
blower motor is easiest to check
temp mix flap on dash can be checked with little hands reaching behind dash if needed (if others check out first) (Flap not moving to the end/closed fully can allow cold air to leak in and cool the heated air)
bad heater valve and vacuum line are discussed elsewhere in the Forum
good luck . . .
Return to Heating and Cooling
