Heater Vac Pipes
Heater Vac Pipes
Postby PARKLANDS » Wed 29.04.2009, 13:56
Dear Elan Se peps
Hi I have a problem ? my Elan Se has been parked up all winter, but the heater system is not working now ? the fan blows fine but i can not control the temp or the flow of air ? i have found some vac pipes under the bonnet that have been eaten ...... which i need to replace first , but which pipe goes on what bit of the engine ? HELP... any other thoughts ?
PARKLANDS
Re: Heater Vac Pipes
Postby HJ2 » Wed 29.04.2009, 14:22
Replace vacuum lines, and check or better replace heatervalve while you're at it :P
Postby PARKLANDS » Wed 29.04.2009, 15:23
HJ2 wrote:Replace vacuum lines, and check or better replace heatervalve while you're at it :P
Doing that but which pipes goes on what bit ...Doh
PARKLANDS
Postby Specky » Wed 29.04.2009, 18:36
A couple of questions first...
Have you got aircon?
how old is the car?
Postby dapinky » Wed 29.04.2009, 20:22
Dave,
If you have a look at this thread i put some pictures in it which helps to show where some of the pipes go!
It is really the ones on the intake plenum (engine) end, but might give you a few clues for any of the eaten ones.
Postby PARKLANDS » Thu 30.04.2009, 13:28
Specky wrote:A couple of questions first...
how old is the car?
Hi its a 1990 Turbo in red with aircon...i know the red its very important.. :D
PARKLANDS
Postby Specky » Thu 30.04.2009, 19:06
dapinky has hit the nail on the head...
IIRC aircon systems have may have an extra vacum pipe that goes to a flap on the heater motor inlet, this pipe runs under the dash thou...
Return to Heating and Cooling
