No Heat At All!!
No Heat At All!!
Postby dermotbell » Wed 14.04.2010, 17:43
A new niggle has arisen to drag me away from working on the Excel.
In the past I suffered from weak heating in the winter and so got chilly, I eventually followed Geoff and fitted a replacement valve. At the time of removal the old valve didn't seem bad at all, especially when compared to Geoff's rusty one. When last winter came I thought the heater temp was a bit warmer (psychological?) but not much.
Now it's summer :) the temp as always seems ok on hot for those chillyish days with sunshine. However, today I now get no hot air at all.
At first I tried exercising the heater control in case the switch that operates the valve was stuck - no difference. So I checked the valve and it moves as it should. Hmmm. There is water in the system and temp reads normal.
Hmmm. Looked at manual and only conclusion I can come to is that the 2 air mixer flaps are not working. Now my understanding is that they are mechanical via a pinion and quadrant linkage to the flaps themselves.
If this is what has failed it may explain my weak heating as one or both may not have been operating correctly in the past.
Has anyone else been through this, and if so is there an easy way to check their operation without ripping out the whole dash etc.
Thanks in advance for any help.
Dermot
PS for once the motoring gods were not completing casting me into the pit as this could have happened in the middle of winter. :lol:
Dermot Bell
dermotbell
Re: No Heat At All!!
Postby M100 TWO » Wed 14.04.2010, 17:56
the temperature gauge is reading 1/4 on the dial ?
M100 TWO
Postby dermotbell » Wed 14.04.2010, 18:01
It normally reads about 1/8 on the dial and is still reading this. I did sometimes wonder about changing the thermostat, but I think I remember reading 1/8 to 1/4 was normal. But as I now have no heat at all, that's why I am leaning towards the flaps.
Dermot
Dermot Bell
dermotbell
Postby M100 TWO » Wed 14.04.2010, 18:10
When mine was that low I had very little heat in the car, could be worth a look at the stat, run the car and see if the hose stays cold then gets hot when the stat opens up
john
M100 TWO
Postby tomac1975 » Wed 14.04.2010, 18:15
Hi,
Mine was similar when i got the car, I changed the stat and the problem was solved so maybe worth a look??? :D
tomac1975
Postby dermotbell » Wed 14.04.2010, 18:18
I guess that could be a possibility but as the car will heat up in traffic and I still get no hot air, I think the stat must be opening otherwise the temp would not rise on the gauge.
The irony here is that I am in the process of stripping out the Excel interior to sort one of the heater fans that has packed up, and it's a git of a job. I really want to avoid stripping out dash here if I can.
I'll do the old pipe feel and see how I get on but I am feeling pessimistic. :(
Dermot
Dermot Bell
dermotbell
Postby GeoffSmith » Wed 14.04.2010, 18:21
Dig your ElanScan lead out - you'll soon see if the thermostat is sticking.
Postby dermotbell » Wed 14.04.2010, 19:08
Geoff
I have thought of this but I'm ashamed to say my elanscan cable is hiding from me.
Dermot
Dermot Bell
dermotbell
Postby dermotbell » Wed 14.04.2010, 19:29
Ah
Scratch that, I have been re-united with my cable. Unfortunately I now have a new laptop since the last use and it doesn't do that type of cable.
Bah humbug.
Geoff, do you have any USB cables left I could buy???
Dermot
Dermot Bell
dermotbell
Postby Candles » Thu 15.04.2010, 07:38
From the dashboard temp knob, there is a push-pull rod that runs back (below the stereo) to the heater flaps. I had to repair mine once. You can access the rod by doing a headstand in the (UK) passenger footwell and looking into the centre pillar area of the dash. Mine had popped out of the plastic union at the heater flap end. It took minutes to fix and all was well.
On the coolant temp matter above, you could just leave it idling in the drive then come back when the engine and coolant are red hot. If there is still no hot air, then it is either Geoff's valve stuck (NB it is vacuum operated), a blocked matrix or an air-routing problem.
Candles
Postby dermotbell » Thu 15.04.2010, 18:41
Got in the car today and touched nothing (the car temp was left selected on hot), 15 mins into the journey I noticed that the air was warm. So i put the heater fans on and yes I now get hot air again. :?
I have selected cold and back to hot and it seems to be working as before. So I am confused.
This appears to point away from the flaps. So either I had an air pocket in the rad (why now?) or the water was not passing thro' the valve??
Dermot
Dermot Bell
dermotbell
Postby dermotbell » Fri 30.04.2010, 07:32
Now that I have elan-scanned the car, it seems that it runs at an average of 83 - 84 deg C. Is this normal temp?
I know I could look in the book but I'm away from home at the moment.
Dermot
Dermot Bell
dermotbell
Postby GeoffSmith » Fri 30.04.2010, 08:17
Spot on.
Postby dermotbell » Mon 03.05.2010, 23:13
Ok, if the temp is good.......................why oh why in winter do I freeze my nuts off because the air only feels lukewarm??? :?
Dermot
Dermot Bell
dermotbell
Postby GeoffSmith » Tue 04.05.2010, 13:10
dermotbell wrote:why oh why in winter do I freeze my nuts off because the air only feels lukewarm??? :?
Since moving down from Newcastle, I've found I need to wear more than a T shirt in Winter. :D
Postby Marcus_uk » Thu 06.05.2010, 11:17
Sorry it took me so long to read this thread...
Have you doubled checked that your new plastic heater valve hasn't got stuck on cold? This has happen to me once or twice. Just free it up only requires your to touch it! I added a squirt of lube and all has been fine since.
Medina Green S2 #165 - Currently for sale :-(
Marcus_uk
Postby dermotbell » Fri 07.05.2010, 20:54
Don't think so as I could see it move when I operated the temp control in the car.
Thanks anyway.
Dermot
Dermot Bell
dermotbell
Postby dans » Mon 10.05.2010, 18:04
Dermot, What's the air flow like out of your heater? I had similarish sounding problems and found it was a collapsed foams section in the wheel arch preventing hot air getting through to he cabin properly.
viewtopic.php?f=29&t=6097&hilit=+heater
Dan
dans
Postby dermotbell » Mon 10.05.2010, 20:31
Dan
Airflow is fine, just a bit cool.
Dermot.
Dermot Bell
dermotbell
Postby Candles » Wed 12.05.2010, 07:46
Did you check the flap control? Whereabouts in Lincs are you as I can show you in about 1 minute where the rod is, if you are having trouble finding it. I'm between Grantham and Sleaford.
Candles
Return to Heating and Cooling
