In the past I suffered from weak heating in the winter and so got chilly, I eventually followed Geoff and fitted a replacement valve. At the time of removal the old valve didn't seem bad at all, especially when compared to Geoff's rusty one. When last winter came I thought the heater temp was a bit warmer (psychological?) but not much.
Now it's summer
At first I tried exercising the heater control in case the switch that operates the valve was stuck - no difference. So I checked the valve and it moves as it should. Hmmm. There is water in the system and temp reads normal.
Hmmm. Looked at manual and only conclusion I can come to is that the 2 air mixer flaps are not working. Now my understanding is that they are mechanical via a pinion and quadrant linkage to the flaps themselves.
If this is what has failed it may explain my weak heating as one or both may not have been operating correctly in the past.
Has anyone else been through this, and if so is there an easy way to check their operation without ripping out the whole dash etc.
Thanks in advance for any help.
Dermot
PS for once the motoring gods were not completing casting me into the pit as this could have happened in the middle of winter.
