Is it possible to fit A/C unit to S2?
Postby bingoking » Sat 25.07.2015, 15:26
Is it possible to retrofit air conditioning to an S2 and has anyone done this?
Silver Esprit V8
Elan S2 M100
Evora GTE No8
Visit LEGS on Facebook and click "Like"
Next LEGS Breakfast meeting, The Red House Hotel, Coupar Angus on 4th October, 10:00am
bingoking
Re: Is it possible to fit A/C unit to S2?
Postby epipete » Sat 25.07.2015, 15:50
I dunno about either the S2 or the SE but I've been wondering the same as I have an SE about to go to sunnier climes.
The pipework and ancillary all look very simple (well if anything Lotus is) but I don't know about the or, indeed, any electrics.
Postby lotustonybassplayer » Sat 25.07.2015, 16:34
Simon p did it read it on here somewhere :bonk:
lotustonybassplayer
Postby epipete » Sat 25.07.2015, 17:55
Yeah, I think it has been done by several folks. Several have even removed it for whatever reason, but no one has given any write-up or commented on any issues. It's all a bit sporadic.
Postby Brit-Car-Nut » Sat 25.07.2015, 21:08
It is probably very complicated as I think you need to remove the dash to install the evaporator and you will need a 6 pos heater control panel. Then you need: compressor, mounting brackets and hardware, different drive belts for the Power Steering and compressor, freon lines, freon, evaporator, condenser, brackets and clips for the lines and condenser, drier and trinary switch, dash switch. See page 166 to 168 (Section 18.03B) for S2 of the V.8 or S2 parts guide and then whatever fuses or breakers Lotus provided for in the main loom. I don't think it is going to be a really easy task. It would be easier if you had a sample available to figure out where everything goes, but, regardless, it is a lot of work.
Postby epipete » Sat 25.07.2015, 22:08
Exactly John and (given all the past fun I've had) I wouldn't want to undertake it myself without much preplanning but fundamentally it is all just meccano really and could all be done in stages with the final pieces being the Belts and system pressurising. The Brackets and ancillary fitting might prove most difficult to source.
It's the lack of a detailed example from someone who's either put one in or taken one out that is regrettably missing. For example I wouldn't much fancy changing a Head Gasket but there are some great write ups on here (HJs springs to mind) which makes me believe I could if necessary :bonk:
Postby Simon_P » Sun 26.07.2015, 17:17
Yes - I have done it.
It isn't exactly a common undertaking and is well enough covered by the manuals. So not much point in writing writing up, unlike HG change which is far more involved and applicable to many.
I didn't remove the dashboard but it wasn't exactly easy easy.
Return to Heating and Cooling
