Coolant leek.
Coolant leek.
Postby gmg31 » Mon 17.04.2017, 16:51
Can any one tell me what the thing is under the NS head light pod please. See photo. I recently noted it hissing after a run out and then the next day there was a small pool of coolant on the floor.
gmg31
Re: Coolant leek.
Postby alan e » Mon 17.04.2017, 17:00
Its the rad air bleed valve you may need a new seal
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
Re: Coolant leek.
Postby Steve A » Mon 17.04.2017, 17:02
It's where you bleed the coolant system, has something just become loose hence the leak :?
Re: Coolant leek.
Postby gmg31 » Mon 17.04.2017, 18:05
Thank you, that was far simpler than I expected. I'll order a new seal. is It an Allan key. Thanks for your help
gmg31
Re: Coolant leek.
Postby Steve A » Tue 18.04.2017, 12:14
It's probably just come loose
Re: Coolant leek.
Postby gmg31 » Wed 19.04.2017, 07:14
That's great, thanks for your help
gmg31
Re: Coolant leek.
Postby Dave Eds » Wed 19.04.2017, 08:16
This one?
Re: Coolant leek.
Postby HJ2 » Wed 19.04.2017, 09:40
Re: Coolant leek.
Postby GeoffSmith » Wed 19.04.2017, 11:32
Did it happen in Wales?
Re: Coolant leek.
Postby lotusflasherman » Wed 19.04.2017, 15:05
GeoffSmith wrote:Did it happen in Wales?
:lol: you're just being an old pedant, like me ... "It's not what I said, it's what I meant."
on a similar vein ... or probably 'vain' to the youngsters :-D ... I read on an MX5 forum lots of discussion about 'instability under breaking for a corner" ... and I thought that was a trait of old Lotus cars ... :lol:
Re: Coolant leek.
Postby gmg31 » Mon 01.05.2017, 10:49
Intersterstingly mine looked nothing like the photo above. Mine was a small insert about the width of a pencil. It was a struggle to remove because the head was smooth but once removed I replaced it with a bolt as a temp fix.
gmg31
Re: Coolant leek.
Postby muley » Mon 01.05.2017, 11:03
gmg31 wrote:Intersterstingly mine looked nothing like the photo above. Mine was a small insert about the width of a pencil. It was a struggle to remove because the head was smooth but once removed I replaced it with a bolt as a temp fix.
Sounds as though the head had snapped off.
Re: Coolant leek.
Postby tb10 » Mon 01.05.2017, 11:40
And if this happens in the middle of nowhere a wheel bolt will do the trick and get you home! :shock:
tb10
Return to Heating and Cooling
