Steel Radiator bypass pipe
Postby sinannasirli » Mon 26.03.2018, 11:44
Any news how to get one, apart from selling my kidney?
Thank you
Sinan
1996 Lotus Elan Turbo S2, Empire Green, No 766
1995 Maserati Ghibli 2.0
2000 Porsche 996 Carrera 4
1969 Chevy K10 Suburban 4x4 i6 250ci
1970 Opel GT
1953 Willys CJ-3B Jeep
1958 BMW R26 Motorcycle
sinannasirli
Re: Steel Radiator bypass pipe
Postby Brit-Car-Nut » Mon 26.03.2018, 13:36
Sorry, no short-cuts or easy prices.
The part number is A100E6338S
They have gone obsolete (02/09/2013) and they were outrageously expensive (£290.92) when they were available.
SJs show them available at £264.47
You can try finding a used one, but expect it to be rusted like yours.
I pulled a couple from spare engines and they were all damaged in one way or another.
The pipes were powder coated on the outside but appear to have had no treatment on the inside.
Don't forget to order a new O-Ring A100E6339S - £2.82
ANOTHER GOOD EXAMPLE WHY COOLANT SHOULD BE CHANGED REGULARLY.
Postby sinannasirli » Mon 26.03.2018, 15:49
It does not come up under elan , only comes when directly quoted with the stock code.. So they might not even have it in stock.. This is really expensive for what it is..
Do you think if a N/A version can be bent/altered to be used?
Thank you..
Sinan
1970 Opel GT
sinannasirli
Postby sinannasirli » Mon 26.03.2018, 15:51
I definitely agree with this.. The Previous Owner managed to even damage the cylinder head with corrosion.. Thankfully it could be repaired..
I cannot find a local guy to replicate due to the special flaring/ending where the o-rings go..
Sinan
1970 Opel GT
sinannasirli
Postby Brit-Car-Nut » Mon 26.03.2018, 17:25
sinannasirli wrote:It does not come up under elan , only comes when directly quoted with the stock code.. So they might not even have it in stock.. This is really expensive for what it is..
Thank you..
Sinan
The part number has gone obsolete at Lotus. There are none in the US, but other dealers / resellers might have one. SJs show it as current and with a price. That usually means they have some.
Maybe you can get someone to make the major portion and weld the o-ring end to the new portion?
Postby Brit-Car-Nut » Mon 26.03.2018, 17:35
As a favor, I CALLED SJs to verify they have stock and they DO NOT!
They say that if the O-Ring end is reusable, you can buy the NON-Turbo pipe and make one out if the two parts.
They have a picture of the pipe using A100E6337S, so you can use it to see if that will help.
Postby sinannasirli » Mon 26.03.2018, 20:57
Brit-Car-Nut wrote:As a favor, I CALLED SJs to verify they have stock and they DO NOT!
THANK YOU VERY MUCH FOR THE EFFORT!!
The one i have the o-ring end is uselese.. so we skip that option as well? Do I understand correctly? I can only use the remaining part of the N/A , if I can reuse my o-ring end?
i thought borh pipes would have some ending, so thought of cutting the o-ring end to weld to mine.. but looks like turbo one is more curved..?
1970 Opel GT
sinannasirli
Postby sinannasirli » Tue 03.04.2018, 18:57
As good as new..
1970 Opel GT
sinannasirli
Postby sinannasirli » Tue 03.04.2018, 19:00
Old vs new. custom made made from Aluminium
1970 Opel GT
sinannasirli
Postby John_W » Fri 13.04.2018, 20:14
Just one kidney for that?
Postby sinannasirli » Fri 13.04.2018, 21:21
Meanwhile my friend who did me a favor manufaxturing the pipe is
asking if you guys would be interested for the same pipe for 100 gbp each .. postage paid ?
1970 Opel GT
sinannasirli
Postby John_W » Fri 13.04.2018, 21:45
It looks beautiful, but I’ve never checked the condition of mine. I suspect nobody else has unless it has leaked. How did you discover the problem?
Postby sinannasirli » Fri 13.04.2018, 21:52
Actually the car was losing small amount of coolant when parked. And also there were a lot of bubbling in the coolant reservoir on throttle. Suspected leak at head gasket and this was discovered on a visual check when the head/turbo was off..during the head gasket change..
(Still had some leak of exhaust gasses into coolant, so the head gasket change was necessary, but this was also a major issue...)
Also the water was getting dirty brown..(rust)
1970 Opel GT
sinannasirli
Postby John_W » Fri 13.04.2018, 21:54
Useful info. I’ll check mine when I change the anti-freeze next month.
Postby Mark Hardwick » Wed 22.08.2018, 12:29
Hi Gents
Has anyone tried one of the fabricated alloy pipes ?
are they , or any alternative still available ?
thanks
mark
Mark Hardwick
Postby sinannasirli » Wed 22.08.2018, 22:43
Hi Mark,
if you are talking about the one i manufactured, it solved my problem and i am still using it.
Sinan
1970 Opel GT
sinannasirli
Postby Mark Hardwick » Fri 24.08.2018, 20:21
Hi Sinan
Yes, the alloy one, i tried to PM you, but as newby not allowed, can you still arrange for your friend to make one ?
I seem to remember £100 all in ?
Mark
Mark Hardwick
Postby sinannasirli » Sun 26.08.2018, 13:38
Hi Mark,
i also received your pm, but i think its better to write here so others see it too.
My friend was telling that he needs to make a couple of them to produce as its the same effort to make 1 or 5. 100 gbp was quoted for 5-10 pcs...
i had asked here but it was not possible to get more people interested, so he only made one for me, wih some increased costa and a few beers at the pub.
i am happy with it , it was a snug fit, only the other side where the hoses attach wasnt 100% as the original angle but this caused no issue as hoses can be bent easily..
We can maybe produce another run if more people would be interested.
Sinan
1970 Opel GT
sinannasirli
Postby MarkP » Tue 20.04.2021, 22:51
I seem to have coolant weeping from where this pipe enters the housing. I have not disassembled anything yet as I need to replace a couple of Samco hoses at the same time and the leak is not massive at this point. Assuming the pipe has corroded and that’s what’s causing the leak, does anyone have a source for a new pipe? Any suggestions welcome.
MarkP
Postby sinannasirli » Tue 20.04.2021, 23:38
i am still using mine..no leak.. happy..
My friend is not working at that company any more, though we still can be able to make a production run if people get interested..Just not sure if i have shrown the samples away .
The end part where the o-ring sits it the main difficulty for producing this pipe.. not many shops could be able to produce this if i remember..
1970 Opel GT
sinannasirli
Return to Heating and Cooling
