Brit-Car-Nut wrote:
ANOTHER GOOD EXAMPLE WHY COOLANT SHOULD BE CHANGED REGULARLY.
sinannasirli wrote:It does not come up under elan , only comes when directly quoted with the stock code.. So they might not even have it in stock.. This is really expensive for what it is..
Do you think if a N/A version can be bent/altered to be used?
Thank you..
Sinan
Brit-Car-Nut wrote:As a favor, I CALLED SJs to verify they have stock and they DO NOT!
They say that if the O-Ring end is reusable, you can buy the NON-Turbo pipe and make one out if the two parts.
They have a picture of the pipe using A100E6337S, so you can use it to see if that will help.
