Drivers side leak
Drivers side leak
Postby Rice crispy » Sat 01.09.2018, 21:43
I appear to be leaking from my drivers side :shock:. I expect it's an age thing. Coolex rad ordered just in case will be booking it in on Monday with my mechanic to check and replace. Does anyone know the y hose part number just in case it's that and I would rather have all the potential bits just in case so I'm not stuck waiting before the festival
Rice crispy
Re: Drivers side leak
Postby Rice crispy » Sun 02.09.2018, 08:37
Hose ordered from sjs
Rice crispy
Postby Rambo » Sun 02.09.2018, 09:30
Are you sure it's a coolant leak ? Put some newspaper underneath to determine the exact point of the leak and that it is water based
PS if its oily and just in front of the O/S wheel it will be the oil cooler or associated pipework :(
Postby Rice crispy » Mon 03.09.2018, 21:55
Rambo yep definitely cooling as I'm loosing coolant not oil and I had the dreaded oil cooler hoses rebuilt last year. Thanks for the heads up though. :goodposting:
Rice crispy
Postby Rambo » Tue 04.09.2018, 09:22
For anyone else who may be considering replacing their existing radiator with a Coolex one, I can personally recommend them. They are good and well made. Further details below.....
Edited to remove the link to the baby Elan's and not our M100's
Postby RonR » Tue 04.09.2018, 10:46
*Cough*
Hi Rambo, just thought I'd point out that the link above is pointing at the '60s - '70s Elan and +2 radiators
I couldn't find any info about the M100 rads on the coolex website, but they're on Epay HERE (Bare Ally) or HERE (Painted)
Cheers,
Ron
Postby dapinky » Tue 04.09.2018, 11:00
Further to the above, as opposed to just buying from eBay I'd recommend phoning the company and speaking to Steve directly. (and mentioning that you are from LEC).
He has always looked after LEC members in the past, and has offered better prices when spoken to (free P&P) and is a great guy to chat to.
Postby muley » Tue 04.09.2018, 11:16
Another vote for Coolexperts. I've installed 4 of their radiators ~ just done the 4th. with never a problem.
Jin
Postby Rambo » Tue 04.09.2018, 12:14
RonR wrote:*Cough*
Cheers,
Ron
Hi Ron - thanks for that. I must have posted the wrong link so I will remove the erroneous link in my above post :oops:
Postby Rambo » Tue 04.09.2018, 12:16
dapinky wrote:Further to the above, as opposed to just buying from eBay I'd recommend phoning the company and speaking to Steve directly. (and mentioning that you are from LEC).
Agree with Dave. That's the route I went down when I did mine. Very good customer service
Postby Kipperozzy » Tue 04.09.2018, 17:46
I agree , fitted the black painted one over the winter, no issues and works well :agree:
Kipperozzy
Postby Rice crispy » Tue 04.09.2018, 22:56
I didn't think to ring, I already have the expansion tank so know how good their products are
Rice crispy
Postby Rambo » Thu 06.09.2018, 13:21
Yes, I saw one of the Coolex header tanks in one of Jim's many M100's and thought it ĺooked good. Hope you spent a bit extra to get the one with the inbuilt sight glass ?
Postby Rice crispy » Thu 06.09.2018, 21:02
Yep have the sight glass
Rice crispy
Postby Rambo » Thu 06.09.2018, 21:07
Must get one to tart up the Black Beastie's engine bay ;-)
Postby Rice crispy » Fri 07.09.2018, 23:08
Do look good especially compared to a yellowing plastic one. Rad changed over today, the old was starting to disintegrate and was leaking at the bottom where it joined the plastic end cap, and some of the fins were flaking off as well. The bottom hose was fine so the new one will go with the other spares.
Rice crispy
Postby Rice crispy » Mon 24.09.2018, 20:55
FFS appears like the top hose has let go tonight :-), I've ordered one from sjs now but am worried it's not going to be here in time for fitting and testing by Friday for the festival. Is there another hose that I could get from another car as a temporary fix? It's too dark to get it off tonight to confirm.
Rice crispy
Postby Steve A » Mon 24.09.2018, 22:18
You have a pm :poke:
Postby Rice crispy » Mon 24.09.2018, 23:17
Replied Steve :D many thanks for the offer. I've had a look now it's cooled down and it's split right next to the clamp at the engine end.
Rice crispy
Postby Rambo » Tue 25.09.2018, 08:43
Is there enough play in the pipe to stretch it and make a cut and then reclamp with the Jubilee clip to effect a temporary repair ?
Sounds like you will be looking to buy a new set of Samco hoses sometime soon ? If so, James at Amber Performance might still be giving LEC discounts ?? I'm sure someone will be able to confirm this.
Return to Heating and Cooling
