Oil Cooler Dowty Seals (washer seals)
Postby FunElan » Tue 19.03.2024, 22:19
Hi all,
So the banjo bolts on the oil cooler are a 22mm head, but am I correct in understanding that they reduce down to the size of an M16? I read that here somewhere. Does that mean I need 4 M16 dowty seals vs M22 ones?
For us in the US...an easy source for these, assuming we correctly decide the size needed: https://setrabusa.com/products/dowty-se ... 8686961718
Thanks,
Matt
FunElan
Re: Oil Cooler Dowty Seals (washer seals)
Postby Tuga2112 » Tue 19.03.2024, 22:47
i know the information is on the forum somewhere.
I know many years ago... say probaby 6 i had an issue with the oil cooler and needed to replace it. the details are somewhere in the 10+ pages of progress of my Yellow car's thread.
search over the pages based on the timeframe with a find text for "oil cooler" may shed some light.. i guess the problem is that i dont know how long ago that happened and i certainly dont have Pinky's memory
Postby Simon_P » Wed 20.03.2024, 08:38
M16 = approx 16mm id, 22mm od
With Metric threads where you see Mxx that's a size rather than a dimension so an M15 dowty washer fits an
M16 thread.
Postby dapinky » Wed 20.03.2024, 11:21
Matt, you are correct in your thoughts.....
..... the OE oil cooler is a 'standard' radiator (with standard dimensions) from an outside manufacturer. The mounting brackets are bespoke to the Elan, which is the only reason it can't be replaced in 10 minutes with an off-the-shelf item - albeit that it can be done with a bit of ingenuity and some aluminium sheet.
The 'standard' fitment for an oil cooler radiator is M22 female threads, but there is no room on top of the radiator to fit 'standard' barbed hose fittings, so a banjo fitting is used.
I don't know why they didn't use a 22mm banjo, but there must be a reason (because the narrower bore pipe fits a smaller banjo I suppose) - so the radiator fittings have a reducer bush screwed in to reduce the thread to M16.
so, short answer, yes you need 4x 16mm ID seals.
Postby FunElan » Wed 20.03.2024, 19:00
dapinky wrote:Matt, you are correct in your thoughts.....
Simon_P wrote:M16 = approx 16mm id, 22mm od
M16 thread.
Thank you Simon and Dave, for confirming my suspicions. I suppose I can add to the wiki, since this information should be easily accessible and there's no point in spending extra GBP/$ on a piece that's available elsewhere.
FunElan
Postby Simon_P » Wed 20.03.2024, 22:00
Sorry just noticed typo!
Simon_P wrote:With Metric threads where you see Mxx that's a size rather than a dimension so an M16 Dowty washer fits an
M16 thread.
Postby FunElan » Thu 21.03.2024, 20:14
Here's where I bought a pack: https://setrabusa.com/products/dowty-seal
FunElan
Postby FunElan » Wed 17.04.2024, 22:27
And here's how I removed the oil cooler lines without draining PAS fluid. The suspension is out of the way though.
FunElan
Return to Heating and Cooling
