Cooling Fans Direction
Postby dunnlor » Sun 04.05.2025, 21:22
Should the radiator cooling fans on a Fed be set to pull or push?
Thanks,
Tom
dunnlor
Re: Cooling Fans Direction
Postby FunElan » Sun 04.05.2025, 21:51
I think they should be pulling from the fresh air in front of the car
FunElan
Postby Fredjohn » Sun 04.05.2025, 22:00
Rad needs fresh cold air.
If fans are in front of rad, they pull air into fan and push it into rad. If they are behind the rad, they'll pull air through rad.
This applies to any car really.
Postby dunnlor » Sun 04.05.2025, 22:16
Thanks all.
I was pretty sure that fans that sit behind the radiator should be setup to pull fresh air through, but wanted some confirmation before I actually put them in.
Tom
dunnlor
Postby Tuga2112 » Sun 04.05.2025, 22:55
general rule is pretty simple.
whichever way the air flows when the car is moving forwards is the direction the fans will be making the air flow.
the fans will never push air in the oposite direction of flow when the car is moving... for obvious reasons
Postby Fredjohn » Mon 05.05.2025, 08:11
Tuga2112 wrote:general rule is pretty simple.
And then there's the original Mini :D :D :D
Postby dapinky » Mon 05.05.2025, 10:15
Fredjohn wrote:And then there's the original Mini :D :D :D
I think Joao has never owned an early Beetle, either.......
(cue..... loads of other obscure vehicles from Tata etc which defy the perfectly-sensible normality that was being described!)
Postby Tuga2112 » Mon 05.05.2025, 11:06
you both are absolutely correct.
i did say "general rule" :-D
Return to Heating and Cooling
