Cooling Fans, (UK, Turbo, no air-con)
Postby Gordon » Sun 16.07.2006, 11:32
So it turns out, one of my cooling fans is siezed. That in itself condems the one fan, but to my dismay, the cowels of both fans are almost completely rusted away. certainly beyond repair.
Does anyone know which parts bin the fans were borrowed from? - Pictures attached.
***UPDATE***
Turns out they may be Renault Traffic 2.5D. Anyone care to confirm this?
1990 M100, Calypso Red
2005 Vectra C....
Gordon
Renault Fan
Postby Gordon » Sun 16.07.2006, 15:47
Right - how's this!
RENAULT, R25 2.0 TS-GTS, from 1984
RENAULT, R25 2.0 TS-GTS-TX-TXE-GTX, from 1984
RENAULT, R25 2.0 TS-GTS-TX-TXE-TI-TXI-GTX, from 1984
RENAULT, R25 2.1 TD-DX, from 1984
RENAULT, R25 2.1 TD-GTD, from 1984
RENAULT, R25 2.2 GTX, from 1984
RENAULT, R25 2.5 V6 Turbo, from 1985
RENAULT, Trafic II, from 1989 to 1989
RENAULT, Trafic III, from 1996 to 2001
2005 Vectra C....
Gordon
Postby Candles » Sun 16.07.2006, 16:32
Candles
Re: Renault Fan
Postby Specky » Sun 16.07.2006, 19:12
gordontwist wrote:Right - how's this!
Good find :D .... how much each...does the cage come seperate...
Postby Sy V » Mon 17.07.2006, 07:31
This is indeed an excellent discovery Gordon - thanks.
Cooling Fans
Postby Ghost » Mon 17.07.2006, 20:05
Had the same problem with one of my fans, but after dismantling, a few sharp blows on the fan spindle loosened it. Ran it for a little while off the battery and then replaced in car.
Now seems OK, but intend to run every month to make sure they both run when needed in 'anger'!
Spending the kids inheritance
Ghost
Postby Simon_P » Wed 19.07.2006, 11:40
The parts manual lists an alternative A100k6024F
Does anyone know where the alternative is from? I have 1 of each on my S2. The I assume that the different one is the alternative - it has a plastic shroud and modified mountings. Looks to be a better unit and is rust proof.
Simon
Postby Specky » Fri 24.11.2006, 19:32
The search continues...
I'm still trying to find those bloomin Renault fans and a price..
It's a Renualt Air conditioning fan.. :shock: My 4rse..
What I know is...
Lotus Pt No A100K0017F
Lotus Pt No A100k6024F (Alternative)
Old Valeo OEM Pt No 7700795199 :-D
FrigAir Pt No 0509.1627
Aimrad Pt No 5509.1627
Renault Pt No
7700802142 Still need to check with Renault.
Valeo motor confirmed
More information found here
Thanks Gordon
Postby Specky » Fri 24.11.2006, 20:08
I think it is a valeo item... :-)
See here
Start with the vehicle tab... Renault... 25..etc..
There's drawings as well...
I will get there... :evil:
Postby Specky » Tue 28.11.2006, 21:01
UPDATE
From the R25 equivalent of Sy...
Daniel Wrote
Hi David,
this looks like the fan for the AR4 Automatic transmission fluid cooler, right?
It normally is badly rusted, really Renault should be ashamed :D
The part number of the ATF-cooler fan is 7700802142. It should cost you around 150 Euros... :(
This information is not yet confirmed, but will be soon...
Renault Fan
Postby Gordon » Tue 28.11.2006, 22:31
Found a better picuture;
It's the culprit, and just as rusty...
This is the fluid cooler for the Renault AR4 auto box, as fitted to some 25's...
dosent look like it'll be a source of rust free one's in the breakers yard :shock:
I'm still running with only one fan... seems to be OK for the winter :oops:
Gordon.
[/img]
2005 Vectra C....
Gordon
Postby Specky » Tue 28.11.2006, 22:40
:smt026 :smt026 :smt026 :smt026 :smt026 :smt026 :smt026 :smt026 :smt026 :smt026 :smt026 :smt026
We got there..
Postby Paul.P » Tue 28.11.2006, 22:59
Got any prices on these ?
Postby Specky » Tue 28.11.2006, 23:03
Paul.P wrote:Got any prices on these ?
Only through a German contact... 131 Euro's estimate...
Pt No 7700795199 from UK Renault £176:85
Pt No 7700802142 from UK Renault £176:85
Both are good numbers, but I would use the top one..
Week - 10 days back order.
Both Lotus nubers are obsolete, but they used to cost £68 + vat
I still have other sourses available that should be cheaper...
Postby Specky » Thu 30.11.2006, 15:18
I don't want to jump the gun, but I've found the fan assy for
£68
Unfortunately they only have one, but he's checking his supplier for more.
Just awaiting photos for a positive identification.
More details to follow
Postby Specky » Thu 30.11.2006, 16:38
Just ordered one at £68 pounds... :-D
Lets hope it's the baby I want...
It will take three months to verify this..
I always was a little slow. :wink:
Postby Paul.P » Thu 30.11.2006, 19:15
Dave, do these have metal frames or plastic ?
Postby Specky » Thu 30.11.2006, 20:06
Paul.P wrote:Dave, do these have metal frames or plastic ?
Honestly I don't know.. I'm assuming it's metal by the pics and Pt No
I won't know for a while..
Cooling Fans
Postby algirdas » Sat 02.12.2006, 04:20
Dear Dave:
Do you or anybody else have an idea as to how many CFMs these fans flow?
Sincerely,
Algirdas
Noli illegitemi carborundum.
algirdas
Cooling Fans
Postby algirdas » Sat 02.12.2006, 04:36
Dear Dave:
Also, what is the diameter of the fan and what are the distances between the mounting holes?
Sincerely,
Algirdas
algirdas
Return to Heating and Cooling
