Was searching for ECU or ECM - finds NO results ?!
Searching the S2 register thread with a number finds NO results.
I don't believe the search function is fully functional/searching.
simonbuk wrote:Was searching for ECU or ECM - finds NO results ?!
RonR wrote:Works for me - just did a search for ecu* and got 114 matches.
dapinky wrote:The search function in php.bb (the software used for the forum) is basic to say the least....
..... it requires 3 matching characters, and you can use the * as a wildcard beyond that. You cannot search for a 2-letter (or number) item, as it won't do that.
Like all other searches, it will only find things that you actually look for, and only if it matches the spelling (in search and target).
You can use boolean operators to help in searching for a particular phrase or combination of words - but again, it is a bit choosy if it likes it!
For example, putting "brake calliper" into the search box will not give the same results as "Brake + Calliper" as the first looks for a 2-word phrase, and the second looks for a post containing the 2 words, not necessarily together. - either way, it won't help if the person who wrote about the brakes wrote it as "brake caliper".... so maybe try "brake +break calliper +caliper" - to give you the biggest chance of finding something.... except then you have to sort the wheat from the chafe.
You may end up with a search looking like brake +calliper +upgrade +front +rebuild +pads -piston -vauxhall.......... and that may get you a few posts with the information you want to find the part number for the front brake pads for a hi-spec upgrade, whilst ignoring all those posts with the OE callipers - it is a bit of a lottery, but such is like!
Return to Forum (not Elan!) Questions/Problems
