Using quotes..
Post your cries for help about using this forum. Please do not use this section for Elan-related problems.
Using quotes..
Postby paulwatkins » Tue 23.01.2007, 16:52
When you use the quote function, how do you get the bold "username said:" bit to appear? :?
paulwatkins
Re: Using quotes..
Postby ailwyn » Tue 23.01.2007, 16:59
paulwatkins wrote:When you use the quote function, how do you get the bold "username said:" bit to appear? :?
Like this?
just make sure the opening quote marker (inside the [] brackets) is - quote="paulwatkins"
e.g. [ quote="paulwatkins" ] [ /quote ] (make sure you remove the spaces - they have been added so that the text will show). The text between the two markers will then be placed in a box as above.
Postby paulwatkins » Tue 23.01.2007, 19:48
ailwyn wrote:just make sure the opening quote marker (inside the [] brackets) is - quote="paulwatkins"
Like this? :-D
Cheers Ailwyn
paulwatkins
Postby ailwyn » Wed 24.01.2007, 00:51
Spot on! 8)
Postby Doug » Wed 24.01.2007, 01:06
sounds like he is gearing up to battle Geoff in the "made up quotes" section . . . :-D
also, if you just hit the "quote" box on someone's reply instead of hitting the "post reply" button, it will set up the quote for you and you can then remove some of the quote as needed to show what you wanted . . .
Postby paulwatkins » Wed 24.01.2007, 08:19
Doug wrote:sounds like he is gearing up to battle Geoff in the "made up quotes" section . . . :-D
Like this?
Thanks for the advice guys!
paulwatkins
Postby GeoffSmith » Wed 24.01.2007, 20:20
Dastardy Doug wrote:sounds like he is gearing up to battle Geoff in the "made up quotes" section . . . :-D
And this!
Postby Doug » Wed 24.01.2007, 22:34
geoffsmith wrote:sounds like he is gearing up to battle Geoff in the "made up quotes" section . . . :-D
Re:
Postby stevieshag » Sun 01.02.2009, 23:09
[quote="Doug"][quote="geoffsmith"]sounds like he is gearing up to battle Geoff in the "made up quotes" section . . . :-D
also, if you just hit the "quote" box on someone's reply instead of hitting the "post reply" button, it will set up the quote for you and you can then remove some of the quote as needed to show what you wanted . . .[/quote][/quote]
I have hit the quote button but my quote doesnt appear in a box & it still appears as above... why ?
black lotus elan se (kermit)
Mitsibushi outlander
suzuki gsx 750 W (Gonzo)
stevieshag
Re: Re:
Postby Enright » Mon 02.02.2009, 00:03
No idea - all I did was to hit the quote button before typing this and it worked for me. :?
Re: Re:
Postby stevieshag » Mon 02.02.2009, 06:44
[quote="Enright"][quote="stevieshag"][quote="Doug"][quote="geoffsmith"]sounds like he is gearing up to battle Geoff in the "made up quotes" section . . . :-D
I have hit the quote button but my quote doesnt appear in a box & it still appears as above... why ?[/quote]
No idea - all I did was to hit the quote button before typing this and it worked for me. :?[/quote]
great i am glad thats sorted... :shock: :x
stevieshag
Re: Re:
Postby tweetdriver63 » Mon 02.02.2009, 06:56
[quote="stevieshag"][quote="Enright"][quote="stevieshag"]
I have hit the quote button but my quote doesnt appear in a box & it still appears as above... why ? [/quote]
No idea - all I did was to hit the quote button before typing this and it worked for me. :? [/quote]
great i am glad thats sorted... :shock: :x [/quote]
Go to your profile, and click on the "Board Preferences" tab. Over on the left side, click on the "Edit posting defaults" link. Make sure the first item, "Enable BBCode by default," is marked YES. If it isn't, the quote things don't work. I went into my profile and marked BBCode -- NO, then I tried a post with quotes, and when I previewed my post, it looked just like the problem you're having. If it's not that, I don't know.. Hope that helps, though.
Apparently, as you can see by this post of mine, if you're quoting a post that is messed up that way, it doesn't work when you do it either.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Re: Re:
Postby tweetdriver63 » Mon 02.02.2009, 07:05
Enright wrote:
stevieshag wrote:I have hit the quote button but my quote doesnt appear in a box & it still appears as above... why ?
This one was good, so when I used the quote button, it worked fine. The last one was posted with BBCode off (apparently), so when I quote it, it doesn't work.
'91 Elan SE
tweetdriver63
Re: Re:
Postby stevieshag » Mon 02.02.2009, 07:28
ok done BBCode dont think its made a difference, it hasnt in preview window.
stevieshag
Re: Using quotes..
Postby stevieshag » Mon 02.02.2009, 07:29
Yes it has .. Cheers tweety... :banana: :banana: :banana:
stevieshag
Re: Using quotes..
Postby Sy V » Mon 02.02.2009, 11:26
stevieshag wrote:Yes it has .. Cheers tweety... :banana: :banana: :banana:
'Cheers tweety'!?
Return to Forum (not Elan!) Questions/Problems
